C5 Convertible Trunk will not close?
Old Jul 18, 2023 | 01:48 PM
5oneill's Avatar
5oneill
5th Gear
Default C5 Convertible Trunk will not close?
I have a 2001 trunk on my convertible that will not shut sometimes.
I have opened the door to release the vacuum on it and even with the top down it will not shut.
It sometimes happens and sometimes doesn't.
I have noticed in colder weather it happens more often?
Any help or suggestions would be helpful.
Old Jul 18, 2023 | 01:53 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Did you check the rubber grommets on the lid itself eachside of it?
Old Jul 18, 2023 | 02:04 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Check to make sure there are no obstructions. From there, you can adjust the actual latch. There are screws that can be loosened. Once this is done you can shift the latch into a good position where it will engage. Then retighten the screws. This would also be a good time to lubricate the hinges as well. Good luck!
Old Jul 18, 2023 | 02:10 PM
5oneill's Avatar
5oneill
5th Gear
Default Nothing obstucting the lid
Thanks for this but at this time nothing is obstructing the trunk from closing.
Old Jul 18, 2023 | 02:23 PM
yellow2007's Avatar
yellow2007
You may have worn struts. Try disconnecting them and see how the trunk closes
Old Jul 18, 2023 | 02:58 PM
MWWarlord's Avatar
MWWarlord
While worn struts is certainly a very common issue, they typically make it harder to open the trunk rather than close it. When the struts wear, they become easier to compress, not harder.
Old Jul 19, 2023 | 06:04 AM
Moved to C5 Tech.
Old Jul 19, 2023 | 11:32 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Try posting some photos of the latching mechanisms on the lid and in the trunk, and maybe one of the lid resting in the closed-but-not-latched position.
Maybe someone can spot something off.
Old Jul 19, 2023 | 02:05 PM
3sACROWD's Avatar
3sACROWD
Can you provide a little more detail? What do you mean will not close? (The lid lowers but will not enter the latch or the lid lowers and enters the latch but the latch won't engage or the lid binds and doesn't even come close to closing.)
Old Aug 18, 2023 | 02:38 PM
5oneill's Avatar
5oneill
5th Gear
I have narrowed it down to the fact that early in the morning the latch will not grab and hold. so when it warms up later in the day it closed and is secure. not sure if it has to do with the grease getting gummed up or something but it only happens when its chilly or cold?
Old Aug 18, 2023 | 07:56 PM
grinder11's Avatar
grinder11
Or, perhaps someone has installed an off brand, or incorrect length of strut that may be slightly longer that the correct length strut. If so, it could bottom out, and could be causing the trunk lid to not travel far enough to latch in some situations.
Old Aug 19, 2023 | 06:50 AM
bsn5440's Avatar
bsn5440
Grease gets hard over time-it also get harder when temps drop. Try penetrating oil on the latch then manually close the latch with the trunk open use the remote to open it do that a few times with some penetrating oil each sequence. Then grease the assembly and you should be good for another 20 years.
To C5 Convertible Trunk will not close?
