Clutch sticking only when engaged from a stop
Old Jul 19, 2023 | 10:03 AM
JayhawkCPA's Avatar
JayhawkCPA
Default Clutch sticking only when engaged from a stop
Hello,
I have read all the threads on sticking clutches, which are centric to high RPM shifting/driving the car hard. I have a unique issue I was wondering if anyone else has had. I had a C5 Z with 30k miles, stock except for CAI and possibly a dyno tune. I do not race the car but i will bang off some 1-2 shifts do some spirited driving here and there. The clutch performs flawlessly during the spirited driving (maybe if I tracked it, it wouldn't).
My clutch will stick to the floor 7/10 times engaging from a stop light and getting the car moving forward, it will shifts through all gears fine). Example, if i put the car in 1st gear at a light and keep my foot down on the clutch then return back to nuetral and take my foot off the clutch it will stick to the floor.
it will stick 10/10 times after putting the car in reverse and moving (i.e. back out of a parking spot, pick the clutch up with my toe to put it in first gear and move forward).
I'm tempted to just have the full assembly replaced with remote bleeder and call it a day
Old Jul 19, 2023 | 10:33 AM
MetalMan2's Avatar
MetalMan2
Speaking of remote bleeder, have you attempted to exchange the fluid at all? With the stock bleeder screw it might be a bit messy but could very well be worthwhile.
By the way, I didn't see a question here guessing you want us to affirm your choice to replace everything. There is an intermediate option of installing a Katech remote bleeder, which doesn't require full drivetrain removal. And if fresh fluid doesn't do it I'd suggest replacement of the clutch master cylinder. Both of these are far cheaper and easier than clutch & slave cylinder replacement.
Old Jul 19, 2023 | 10:40 AM
JayhawkCPA's Avatar
JayhawkCPA
Question was if anyone has heard of the clutch issue happening only from a stop...seems unique based on my research.
Old Jul 19, 2023 | 11:12 AM
JayhawkCPA's Avatar
JayhawkCPA
I have not messed with fluid, from my research usually does not yield much result, current fluid has about 5k miles on it. I am going to take the car to a corvette specialty shop and will have them do that.
Old Jul 19, 2023 | 11:13 AM
MetalMan2's Avatar
MetalMan2
That does seem true, most clutch pedal sticking I can recall reading about occurs while shifting at higher RPM.
Have you noticed if there's a difference in the behavior when the engine is cold vs hot?
Old Jul 19, 2023 | 10:00 PM
JayhawkCPA's Avatar
JayhawkCPA
nothing super noticeable, i'd say it's probably worse when hot...speculating.
Old Jul 20, 2023 | 01:09 AM
MetalMan2's Avatar
MetalMan2
It is a weird issue no doubt.
In your described scenario there is pressure against the master cylinder, and pressure is maintained otherwise the clutch would start to grab and the car would roll forward (since it's in 1st).
So what would cause the clutch pedal/master rod to stick despite the pressure pushing away from that? These are my theories/ideas:
  • gunked up master cylinder or slave cylinder, perhaps a fluid flush would help
  • something on the clutch pedal is binding
  • the clutch pedal over-center spring is getting stuck somehow
    • you can try removing it as part of the diagnosis process. Note that some people prefer the clutch pedal feel without the spring anyways.
Short of doing a fluid exchange and/or firing the parts cannon, my suggestion would be to crawl under the dash with a good light, press and hold the clutch pedal, and see what does/doesn't happen. Then repeat after removing the over-center spring. This is all free and relatively quick, albeit uncomfortable.
Old Jul 20, 2023 | 10:03 AM
JayhawkCPA's Avatar
JayhawkCPA
Thanks, I appreciate your time and insight
Old Jul 20, 2023 | 10:07 PM
dainon's Avatar
dainon
Hello,
This happened to me just last month. It got worse when the car was hot. I had 89K miles on my '99. It ended up being the slave cylinder. Because the car had to come apart to get to it, I just had them upgrade the whole thing even though my clutch plate had plenty of life left in it. I went with an Exedy stage 1 clutch, a new GM OEM slave, and the Tick master.
When they pulled the slave out, it was full of gunk. It's possible it could have been flushed and bled, and maybe it would have come back. But once you have made the effort or paid the labor to get to it, you may as well spend a few hundred dollars on clutch parts to just make it all new again.
Hope that helps.
-D
Old Sep 28, 2023 | 09:43 AM
JayhawkCPA's Avatar
JayhawkCPA
Hope that helps.
-D
It does, thank you. I suspect that is the case. I bought the car in 2018 with 22k miles on it from the second owner who barely drove it, I had all fluids changed when i got it but i suspect the slave is gunked up.
Old Oct 25, 2023 | 03:18 PM
PetrofMII's Avatar
PetrofMII
This odd sticking clutch issue popped up on my '03 (approx 22.5k miles) a few days ago. I've done a few Ranger fluid removals which resulted in clean fluid after each single draining of the reservoir (removed fluid is darker, but not black). To buy some time I've installed a 6 inch spring to provide some extra return tension to the clutch pedal which has alleviated the pedal sticking problem. I'll find some time to replace all the fluid, and then if it recurs with the new spring removed I'll replace the master to see if that's the root cause.
I can't believe that a car which was essentially a garage trophy for the prior owners could have a bad slave cylinder, but we shall see. The thought of having to drop the drive train on a pampered, low-mileage, A/E convertible is "inconceivable", as Vizzini would say. (Princess Bride reference)
Old May 18, 2025 | 03:04 PM
JayhawkCPA's Avatar
JayhawkCPA
Thread update...i had the clutch master cylinder replaced with the factory unit and the car has no more issues. No slave or clutch problem was involved.
To Clutch sticking only when engaged from a stop
