One Headlight Up...One Headlight Down....
Old Jul 22, 2023 | 07:16 PM
91LSMAN's Avatar
91LSMAN
Default One Headlight Up...One Headlight Down....
I want to make sure that there isn't something I am not thinking of...
During this time of year I really don't have to use my headlights because I am not driving late or early enough for it to be necessary.
I went to pop on my headlights just to clean them and only the passenger side came up. Drivers side headlight is on, but stayed down. I didn't have any symptoms of a headlight motor failure, no noise, nothing. Last time this happened a few years ago it was one of the headlight motor fuses. I checked and changed them and again, same thing-both headlights come on, but only the passenger side comes up.
Is there something I am missing? I just watched a video about headlight motor replacement and it looks just annoying enough to **** me off. Not that it matters, but I have Radio Flyer headlights, but they have been installed for years with no issues.
Old Jul 22, 2023 | 09:07 PM
95wht6spd's Avatar
95wht6spd
Maybe a gear? I have changed mine in the C4 several times.
You can drive it home, with one headlight...
Old Jul 22, 2023 | 10:23 PM
91LSMAN's Avatar
91LSMAN
Not sure what you meant by drive it home. Duh. I probably wont need headlights until September or October.
The gear was my 1st thought-but everything I remember, read and watched -when the gear was going out, the headlight would still work, but the gear would grind. This just suddenly stopped working with no noise, no grinding, which makes me think electrical-relay, fuse, something along those lines.
Old Jul 22, 2023 | 11:32 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
He means this:
Old Jul 23, 2023 | 12:45 AM
Moved to C5 Tech for some advice on what could be wrong.
Old Jul 23, 2023 | 01:15 AM
MetalMan2's Avatar
MetalMan2
Can you manually actuate the headlight? There's a **** on the back of the headlight (normally obscured by a rubber cover) and you can turn it - doing so should raise the headlight if the gear isn't stripped and the linkage is intact.
Old Jul 23, 2023 | 08:17 AM
yellow2007's Avatar
yellow2007
Replacing the motor is more tedious than annoying and not that difficult. And you can do it all while sitting on a stool. Can you hear the motor trying to run? it would be unusual for all the teeth on the gear to be stripped.
Old Jul 23, 2023 | 04:59 PM
lftmdrm's Avatar
lftmdrm
It is either the gear or the motor itself. You didn't indicate if the motor tries to move or start or make humming noise. Also it could be a headlight module which I have a spare one I can give you. I live in the neighborhood here in Lakewood.
Old Jul 23, 2023 | 05:04 PM
91LSMAN's Avatar
91LSMAN
Ok, I have some more information now-it IS the gear inside the headlight-I think it was bound up.
I manually opened the light this morning, but it took some effort-winding the ****. After doing so, I started the car and turned the lights on. Since I manually put the headlight up, both lights were on and both lights were up. Turned them off, both went down, but this time I heard the gear making the noise. Turned them on again, and this time, both lights came up.
The drivers side gear makes noise, but everything works. Perhaps it was bound up from lack of use. During the summer, I'm never driving at night, no need for headlights.
I have not decided which route I'll go yet. The littlest things tend to frustrate me. I just bought repairs kits from corvette parts center, and found brand new motors on Amazon with good reviews. I bought driver and passenger motors. So this way I have options if I get angry and throw something up against a wall, if I decide to do it myself.
Thanks for the thoughts in the thread. I thought it was something different being that I heard NOTHING from the headlight motor at 1st.
Old Jul 23, 2023 | 07:58 PM
Dads2kconvertible's Avatar
Dads2kconvertible
If I were rebuilding I'd use a brass gear like this one https://rodneydickman.com/product_in...products_id=92
Old Jul 24, 2023 | 04:55 PM
91LSMAN's Avatar
91LSMAN
I've read/watched videos good and bad about both the plastic and metal gears. My mentality is-the plastic gear lasted the 16 years I have owner the car-probably the 20+ years that the car has been on the road.
Not to mention that the early C5s had a metal housing for the headlight gear that closes with screws. The later C5s had plastic housings that use adhesive and are harder to get to stay in 1 piece after replacement. I've got both a gear replacement and entire headlight motors on the way, so I am covered. Who knows, I may swap in a new headlight motor and replace the gear in the old one to have as a spare.
Old Jul 29, 2023 | 07:30 PM
DWC4's Avatar
DWC4
I’d gladly prepay you to ship me your known good module, mine is DOA. $50 plus postage.
Old Aug 6, 2023 | 12:27 AM
lemosley01's Avatar
lemosley01
4th Gear
Hey @95wht6spd is your car still up for sale? I saw the thread was closed. I'm interested in seeing it and I'm up on Clover.
(sorry - hope I don't seem like a stalker).
Old Aug 8, 2023 | 10:25 AM
MosEspa's Avatar
MosEspa
The first time you do a headlight its frustrating. After that you keep your few tools it takes to do this job handy so you can fix them again at any given time and its really an easy process once you do it once and realize how it all works. I get it, it's daunting at first and some of those video's really take their time and make it look more difficult than it is. Good luck!
Old Aug 8, 2023 | 02:38 PM
91LSMAN's Avatar
91LSMAN
It's already done: https://www.corvetteforum.com/forums...wont-work.html
I had started another thread with an issue afterwards, then figured it out a few hours later.
Thanks!!
Old Aug 8, 2023 | 06:44 PM
MosEspa's Avatar
MosEspa
Thanks!!
I remember now.
Old Aug 14, 2023 | 07:01 PM
grinder11's Avatar
grinder11
A lot of this stuff fails, or acts up, due to non use. I hardly ever drive at night anymore. One time a couple years back my driver's side lamp wouldn't open. So I shut the lights off and turned them on a second time. Sure enough, this time the drivers side worked. A month or so later, same thing happened, with the same "fix" done by trying a second time. Since then I've made it a practice to open the lights at least once every 2 weeks. Never had the problem again........
To One Headlight Up...One Headlight Down....
