Remove torque tube without dropping rear cradle ..?
Old Aug 6, 2023 | 09:27 AM
_c5ghost's Avatar
_c5ghost
3rd Gear
Default Remove torque tube without dropping rear cradle ..?
I pulled the stock ls6 after it dropped a valve & ate itself. Was able to separate the bellhousing from the torque tube with no issues. I’d like to rebuild the tt while I’m building the new engine in the mean time. Is it possible to remove the tt from the trans without removing the entire rear cradle? The goal would be to remove the tt and only the tt! If I can save myself the time and leave the rear cradle untouched..
Old Aug 6, 2023 | 01:41 PM
yellow2007's Avatar
yellow2007
I think the rear cradle removal was based on the engine remaining in the car so since yours is out I wouldn't think the cradle needs to be dropped.
Old Aug 7, 2023 | 08:19 AM
feeder82's Avatar
feeder82
I don't think it will work, it probably won't clear the tunnel without lowering
Old Aug 7, 2023 | 08:56 AM
schmuckingham's Avatar
schmuckingham
Wont work. The rear "bell housing" on the TT hits the tunnel way before it comes off the splined shaft, rear cradle has to be removed.
Old Aug 7, 2023 | 10:08 AM
HardcoreABN's Avatar
HardcoreABN
you would need to remove the rear "trunk".
Old Aug 8, 2023 | 10:49 AM
RonSSNova's Avatar
RonSSNova
I tried it with the engine out, it’s a no go.
Old Aug 8, 2023 | 03:18 PM
grinder11's Avatar
grinder11
Ron, can you lower the front of the tube where it attaches to the engine? I ask because I dont know. I do know there is some "give" in the rear suspension and cradle that allow the front of the tube to lower a couple inches. I did this when I removed my engine the first time when I did it the old school way with a cherry picker. There was virtually no way to access the bolts holding the engine to the tube. So I VERY SLOWLY lowered the assembly an inch or 2 in order to access those 5 (?) bolts. This was on my A4 C5. Or, isn't an inch or 2 enough?
Old Aug 8, 2023 | 10:04 PM
RonSSNova's Avatar
RonSSNova
Maybe if you had it on a lift. I was just on jack stands. And of course mine is an auto.
To Remove torque tube without dropping rear cradle ..?
