Oil Pan Gasket Replacement/Engine Support
Old Aug 24, 2023 | 10:16 AM
mickfree's Avatar
mickfree
Default Oil Pan Gasket Replacement/Engine Support
I need to replace my oil pan gasket again! I think i overtightened the front pulley pan bolts and it's leaking from the front of the engine. What I want to know is can I SUPPORT THE ENGINE WITH A JACK ON THE BELLHOUSING? OR IS AN ENGINE HOIST MANDATORY? I basically want to be able replace the pan without the subframe in the way,
Thank in Advance
I'm a novice that is trying to learn how to work on my vette, because shops try to rip you off.
Old Aug 26, 2023 | 01:00 AM
Moved to C5 Tech.
Old Aug 26, 2023 | 07:29 PM
Fast one's Avatar
Fast one
I don't know about using the bellhousing but there are engine support bars that do want you want, they are sold on Amazon, Harbor Freight, etc. You might have to modify a set so the bar support sits on the steel frame and not the plastic fender. Here's a picture of one:
Old Aug 26, 2023 | 07:58 PM
mickfree's Avatar
mickfree
Ok cool thanks so much
To Oil Pan Gasket Replacement/Engine Support
