Is my balancer too bad?
Old Sep 5, 2023 | 03:31 PM
Preston.Corvette's Avatar
Preston.Corvette
Default Is my balancer too bad?
Just picked up this c5 today, finding everything that needs to be done. Its a 2000, I'm not sure if the balancer should be a worry yet. Would it cause any weird sounds when accelerating hard?
Old Sep 5, 2023 | 03:52 PM
Preston.Corvette
I can shoot a longer video if needed.
Old Sep 5, 2023 | 04:49 PM
Dads2kconvertible's Avatar
Dads2kconvertible
It doesn't look like it's wobbling. Try marking it with a paint pen and see if the outer part is moving relative to the inner part.
If it is, then you should replace the balancer soon. Powerbond and ATI are two that are often mentioned as good replacements.
Old Sep 5, 2023 | 04:52 PM
Preston.Corvette
Thanks, I'll have to do that when it cools down a bit.
Old Sep 6, 2023 | 10:34 AM
Preston.Corvette
Originally Posted by Got uid0
Id start with a new tensioner pulley and belt. Cheap and easy fix for a screech belt or even ac belt and ac belt tensioner.assembly.
One of them sounds could be slipping if it sounds like squirrels fighting.
I was planning on grabbing a belt today, see if that does anything. I haven't had a chance to drive it with the mark on the balancer, so thatll be a good chance to do so.
Old Sep 6, 2023 | 11:47 AM
Missileboy's Avatar
Missileboy
In addition to the mark on the pulley, are you checking it at higher RPM's and when it is hot? I have no audio when I play your file. Mine looks like yours until I give it some juice then she moves a little (especially when HOT). I am sending my car to ECS soon for a "boost" so a new balancer is part of that. If it is wobbling under load, you'll want to get that replaced.
Old Sep 6, 2023 | 04:47 PM
Preston.Corvette
Gave the car a small drive, today. Fully up to temp, and a few hard pulls. The mark still looks good. Although I did notice that the rubber piece is cracked. So I'll probably end up replacing it soon anyways.
I did notice a weird brushing like sound on acceleration, I figure that could be the driveshaft coupler or something.
Old Sep 7, 2023 | 07:00 PM
wydopnthrtl's Avatar
wydopnthrtl
A good pulley doesn't wobble that much. IMO its on its way out.
Old Sep 8, 2023 | 10:18 AM
Sourmug's Avatar
Sourmug
I agree
Old Sep 8, 2023 | 10:24 AM
Preston.Corvette
Seems like the general consensus is that it needs replacing. Thanks everyone for the input and advice. I'm ordering parts tonight!
To Is my balancer too bad?
