Today as my car would not start, for the umpteenth time, up on the dashboard, I received the following message " Pull Key, Wait 10 seconds." Then it disappeared! I started it about 15 times without success.
The latest plan is to put in a new key cylinder. I'm going to do it. So far, new starter and new key have not worked! And the DIC code is a security warning.
Anybody see the message or have any other thoughts? It will start tomorrow for sure! Always does.
You should replace the key cylinder housing which will have a new VATS key assembly. It's that part of the switch that contains the contacts that press against the keys resistor pellet. My car does the same pull key wait ten seconds but only during winter months, and it's not voltage related but cold temperatures, one of this days I will figure it out.
You should replace the key cylinder housing which will have a new VATS key assembly. It's that part of the switch that contains the contacts that press against the keys resistor pellet. My car does the same pull key wait ten seconds but only during winter months, and it's not voltage related but cold temperatures, one of these days I will figure it out.
Thats' exactly the plan! I am charging the battery now, I hope it will start tomorrow. If it does start, it goes tomorrow.
The only time you have to do the BCM relearn procedure when changing key cylinder is if you have bought a new key that has a different resistor pellet resistance then the original key.
