Headlights with Holley EFI
Old Sep 10, 2023 | 08:04 PM
Danible's Avatar
Danible
Default Headlights with Holley EFI
Has any of the Drift/Drag guys that have gutted their car and factory wiring, been able to still use their popup headlights with an aftermarket only ecu? (Aware that the aftermarket ecu won't control the headlights, but utilizing a toggle switch or racewire solution switch panel)
Old Sep 18, 2023 | 11:12 PM
Mc556's Avatar
Mc556
I don’t think you will get an answer here. I’ve not personally done what you’re asking but I’m sure you can use one of the auxiliary outputs to trigger the lights but I’d question if you even need to.
Do you not have the factory fuse box and relays ?
Old Sep 20, 2023 | 10:04 AM
mykream's Avatar
mykream
Why not just leave the bcm and the small amount of wiring with it to control the windows, locks, lights etc?
To Headlights with Holley EFI
