Tpms
Old Sep 11, 2023 | 10:11 PM
markw8's Avatar
markw8
Default Tpms
Hi. I have a 2001. Owned since 03. I had the left front sensor stop recording. I replaced it. It absolutely will not program. I actually bought two and tried to program the extra outside the tire. Nothing. The only code is for that sensor. They were bought from Corvette Central. Any ideas before it goes to the dealer.
Mark.
Old Sep 11, 2023 | 10:37 PM
Dads2kconvertible's Avatar
Dads2kconvertible
What part number is on the sensor?
It sounds like CC sent you the wrong part.
Old Sep 12, 2023 | 02:25 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Do you have a TPMS program tool for the new sensor?
Old Sep 12, 2023 | 05:51 AM
markw8's Avatar
markw8
I have the magnet used for programing. I will have to check the part #. They are Dorman, I believe.
Old Sep 12, 2023 | 06:43 AM
jdmvette's Avatar
jdmvette
Night Owl for life
The dorman website does say magnetic activation so I'm not sure why you couldn't activate yours...
If you run out of options I can share the TPMS I found success with
Old Sep 12, 2023 | 04:57 PM
markw8's Avatar
markw8
I double checked the part #. It's correct. The sensor that came out was an unknown name to me. It programmed easy and the other 3 still work. What module do the work through?
Old Sep 12, 2023 | 08:11 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Amazon Amazon
Old Sep 12, 2023 | 09:43 PM
markw8's Avatar
markw8
This is not for my car. I have the magnet needed. It will not program. And it's on the left front where you start.
Old Sep 13, 2023 | 07:47 PM
spfautsch's Avatar
spfautsch
You need to be complaining to the vendor you bought them from and let them help you, or ask for your money back.
If you get your money back (or not) and want to fix your issue post back and I can recommend a set of sensors that will work with a TPMS trigger tool (and not a magnet).
My guess here is the Dorman sensors you were sold cannot be magnetically activated. Most available currently cannot be magnetically triggered. But since you bought them from CC you should take that up with them first.
Old Sep 14, 2023 | 08:58 PM
markw8's Avatar
markw8
Thanks, I will look into that possibility.
Old Sep 16, 2023 | 11:14 PM
markw8's Avatar
markw8
Everything I see on the Dorman part numbers on my sensors are they are programed with a magnet.
Old Oct 9, 2023 | 03:08 PM
Plasticman's Avatar
Plasticman
They lie...
I have 4 Dorman sensors that were installed about 5 years ago, and 1 failed about a year ago.
This past spring I bought a new one from the same vendor (Tire Rack), and my local tire dealer said they no longer have a programmer for that brand.
I had it installed by another tire dealer, and they could not get it programmed.
I tried it with my magnet, and the other 3 sensors all recognized the magnet, but that one (LR sensor) would not.
I ended up taking it to the local Chevy dealer, who programmed it (for $150!) and it worked fine for about 6 months..
Driving last Sat. and about 45 minutes down the road, the TPMS Service message comes on.
All 4 sensors are reading XXX.
Get home, and check codes. All 4 sensors are "belly up".
No other codes, and the FOB works, so can't be the RFA transmitter (so I reason).
Any ideas, other than take it back to the dealer (for a true reaming)???
This is on my 03 Vette.
plasticman
Old Oct 9, 2023 | 11:05 PM
Plasticman's Avatar
Plasticman
Originally Posted by Discount Tire
@PLASTIC MAN we have a location at:8341 Dani Dr Fort Myers, FL. They could help you with your TPMS issues.
Discount Tire,
Thanks!
I am much closer to your store up in Ocala, and I will call them later this week.
They helped a buddy with his TPMS issues in his 06 Vette a couple of months ago.
Plasticman
To Tpms
