Truck Release short
Light blue power to hatch release (z06 so single release solenoid). Has power at ALL times, even after removing Fuse 26 and relay 39!! I've pulled IP fuse panel Connector 3 and confirmed continuity between pin A9 and the connector at trunk... About to run a tone on the wire & see if it crosses somewhere in the harness. Otherwise it is likely the fuse panel itself??!
TIA
Doubt anyone has a diagram of this to confirm its together correctly?!?
GM of course has discontinued... Time to hit the parts section or Fleabay??
Previous owner had clogged udders and water backed up into the fuse box.
I found corroded terminals and broken wires because of this.
I ended up buying a used fuse box off of fleebay for like $75.00 and repaired the two broken wires.
I never tried opening the box up because I read that it isn't really serviceable and those little wires are a bitch once they start popping out.
Good luck
https://www.corvetteforum.com/forums...ank-hatch.html
