Upper Pan Gasket or Timing Cover First?
Old Sep 14, 2023 | 03:11 PM
wrkdWS6's Avatar
wrkdWS6
Default Upper Pan Gasket or Timing Cover First?
In the process of replacing a leaky timing cover gasket and upper oil pan gasket. I installed the new timing cover gasket and cover using an alignment tool. I’m going to check the bottom cover to block alignment using a straight edge. That got me thinking, before I proceed…ideally, should the upper oil pan be installed first or the timing cover?
