New user needs help
Old Sep 13, 2023 | 05:38 PM
theski00's Avatar
theski00
6th Gear
Default New user needs help
I have an 1998 C5
codes I pulled P1221
P1120
P1221 returns immediately when I try to reset it
" Reduced engine power" " Service traction system" " Service active handling"
it all started unexpectedly today after I drove home ...I cleaned all grounds and plugs on intake ( TBS,MAF cleaner, PCM, TAC plugs etc)
tried my best before bothering you all ......any ideas ? all grounds looked good actually even the ones by the headlights I took the box apart and the insides were shiny new on both sides of car ..
Old Sep 13, 2023 | 06:09 PM
mmartinez's Avatar
mmartinez
If proficient with DMM measure across battery terminals should be around 12.5v for a fully charged battery. You could disconnect the negative battery cable for 5- 10 minutes and reconnect that sometimes clears the codes.
Old Sep 13, 2023 | 06:33 PM
theski00's Avatar
theski00
6th Gear
Hello...yes I did that on battery...... battery was in the green good mark ( lower green) when I put my burner tester on it ....I'm going to get a new battery tomorrow and a new alternator...( it has been a little fluctuating in volts as I drive from 12.3 to 14 volts ( but mostly is at 13.8 volts) but I've been meaning to replace both for good measure and ....I ordered a TPS sensor as well
Old Sep 13, 2023 | 07:11 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Search is your friend
https://www.corvetteforum.com/forums...and-p1221.html
Old Sep 13, 2023 | 08:50 PM
ncali's Avatar
ncali
BEFORE YOU CHANGE THAT ALTERNATOR Read the sticky thread above on alternators/.
If you do anything get yours checked and rebuilt. do not turn it in as A CORE
Old Sep 14, 2023 | 03:00 PM
theski00's Avatar
theski00
6th Gear
Default Got it
Well I took apart the TPS sensor hair dryered it put it back together and now everything is fine. There was water in it. Also. All codes are gone the reduced power is gone etc etc wish me luck
Old Sep 14, 2023 | 03:02 PM
mmartinez's Avatar
mmartinez
Good Luck!
Old Sep 14, 2023 | 03:05 PM
theski00's Avatar
theski00
6th Gear
Thank you everybody for your quick responses
Old Sep 14, 2023 | 05:37 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Great news
To New user needs help
