Budget friendly performance radiator
Old Sep 19, 2023 | 05:09 PM
Gdiehl98's Avatar
Gdiehl98
Default Budget friendly performance radiator
Hello, I have my radiator out of the car. Now that I look at it, it isnt looking too good. Before I starting taking stuff apart for a different job, it ran between 200-220 which to my understanding is normal.
Does anybody know of a good radiator that will cool the car better than the stock one that is budget friendly. I don’t really want to spend more than 300 dollars.
Old Sep 19, 2023 | 05:32 PM
Dads2kconvertible's Avatar
Dads2kconvertible
The factory cooling system is more than adequate for most applications.
The Dewitts is an upgrade but you're not getting one for $300. For that budget you're probably limited to the cheapo lines from any parts store. Even a new AC Delco is $450 from Autozone near me.
Old Sep 19, 2023 | 11:24 PM
a_ahmed's Avatar
a_ahmed
mishimoto sells only for c6, but what differences are there between the c5 andn c6 radiators.
We are paying corvette tax on all these radiator upgrades...
Old Sep 20, 2023 | 07:32 AM
redzg's Avatar
redzg
I’ve read more than a couple of threads that noted ECP worked well for them.
https://ecp-radiator.com/products/1997-2004-corvette-c5-aluminum-radiator-6-speed-manual?variant=44422018531642
Old Sep 20, 2023 | 01:53 PM
tabbruzz's Avatar
tabbruzz
Is your car stock or has a ton of mods? The stock rad works pretty darn well depending on use, meaning normal use. If you do not like the 220 temps then tune to have the fans turn on earlier....
Old Sep 20, 2023 | 02:08 PM
grinder11's Avatar
grinder11
Yes, if engine is stock, radiator can be stock, and work just fine.
Old Sep 23, 2023 | 02:07 AM
Gdiehl98's Avatar
Gdiehl98
Default Radiator fan tune
I might just look into that thank you!!! It’s got some. It does still run around 200-220. It was just getting pretty nasty so I am exploring my options. But I will definitely look into that
To Budget friendly performance radiator
