Continuous Water Pump Issues, Really Need Help!
Old Sep 27, 2023 | 08:08 PM
snaitaz@aol.com's Avatar
snaitaz@aol.com
@98CorvetteTas I am certain that our vehicles' water pump rotates in a counter clockwise position based on my research and some information found here on CF. But if you want to make sure, Google is your friend, plug in ...what is water pump rotation for 1998 corvette. There is also a write up on LS1Tech forum. Look up the parts numbers on Rock Auto and it will tell you the rotation as will other vendors' web sites. Good luck. Cheers!!!
@jim993 Ha you beat me to it my brother. Happy vetting cheers!!!
Old Sep 27, 2023 | 08:12 PM
snaitaz@aol.com
I forgot to mention that a forum member had posted a pdf file of corvette part number for various years which is a wealth of information. Some parts list not only the OEM number but also an AC Delco number where appropriate.
Edit: also if you want a copy of that file LMK itis a wealth of information
Old Sep 27, 2023 | 08:14 PM
snaitaz@aol.com
Originally Posted by 98CorvetteTas
I believe mine had a proper gasket rather than the little O-Ring style gasket that I've seen before but I'm not 100% sure about it. Do you know which years had which type of thermostat housing gasket?
Rock auto will tell you which is which.
Old Sep 27, 2023 | 08:22 PM
98CorvetteTas's Avatar
98CorvetteTas
Cruising
I think it's time for me to consult good old Rock Auto and maybe give them and/or Summit Racing a call and verify exactly which pump I should get for my car.
Old Sep 27, 2023 | 08:27 PM
98CorvetteTas
Cruising
@vette4fl @jim993 @snaitaz@aol.com I want to thank you guys for all of the helpful advice and information. You guys don't know just how much I appreciate it. The pump started making noise today so I'm now pretty much certain that it is indeed the issue. I'll be talking to the mechanics again in the coming days to hopefully iron out exactly which pump will be going on the car next and when it can be done. I'll keep you guys updated.
Old Sep 29, 2023 | 10:58 AM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I'm just talking out of my butt here.
I can't say I've ever seen a standard rotation water pump in any factory serpentine accessory drive system in my life. Maybe there is a design out there somewhere, but in a C5 it turns opposite the crank.
There are over 2 dozen leak points for coolant in a c5 engine bay alone. I'm wondering if you have something else going on besides the water pump problems. Especially if you are constantly smelling coolant.
LS water pumps are known for being kind of junky, and NAPA is not the same company of years past. I have had very good luck with Autozone LS water pumps.
People often ask me why I have never changed the original factory water pump in my 97. Even after having the engine apart multiple times for mods and then an actual engine replacement I still have the stock original pump in there. Why? because it's not made in Chi NA, it doesn't leak, and it works.
Old Sep 29, 2023 | 11:12 AM
vette4fl's Avatar
vette4fl
The coolant reservoirs are known to sprout tiny cracks as they age and can seep fluid.
I’m about to change out my pump and hoses, just because they’re all original 2004, and also the reservoir because of that reputation.
Old Sep 29, 2023 | 11:23 AM
Mr. Black's Avatar
Mr. Black
I agree V4fl. The tanks can be very problematic especially in cars with a high amount of heat cycles and age on them.
Thankfully water pumps are incredibly easy to change on these cars. For such a cramped engine bay it can be done in under an hour.
As replacement car parts quality have continued to decline in recent years we're going to see the preemptive and preventative parts replacers get bit in the butt by junk parts causing more problems than if the original parts had been left in place.
Old Sep 29, 2023 | 03:33 PM
grinder11's Avatar
grinder11
I believe heat cycles are as bad, or worse than, age alone. Even though I know they're not cheap, Edelbrock makes a great water pump for the LSx engines. I paid a bit over $300.00 for mine 9 years/50,000 miles ago. Absolutely no issues. They advertise them as having about 20% more low speed flow than OEM, with stock flow at high RPM. Plus, they're rebuildable. Just thought I'd throw this out there, FWIW...
Old Sep 29, 2023 | 03:48 PM
grinder11's Avatar
grinder11
Editing is done. What do you think I should do regarding my issue?
One thing I recommend is buying a quality NEW pump, NOT a reman. Get either the pump I mentioned, Edelbrock, or a genuine GM pump. One IMPORTANT TIP:
Remove both belts BEFORE spilling any coolant on them. Put them on the bench, wherever. If you spill enough coolant them, your belts will squeal like you wont believe. I ruined both of my under 15,000 mile belts by getting them soaked good with Dexcool. Tried brake cleaner, carb cleaner, even belt dressing. NOTHING helped. Car sounded like a flock of seagulls under the hood. Embarrassing big time, because everybody looks when you drive by, to see what the Hell is making all that noise!!!
Old Sep 29, 2023 | 04:13 PM
grinder11's Avatar
grinder11
Wow, talk about making things confusing. If this is indeed the case and they have been ordering parts that are substitutes for 251-744 it could explain all of my issues. Regardless of brand if they're spinning the wrong way they're going to be destroyed eventually. So you're 100% certain that my pump spins counter-clockwise from the factory? I'll make sure that they pay attention to that when ordering if that is the case.
If the pumps were spinning the wrong way, you would have overheating issues, too. Which you've clearly stated you do not have. I think a system pressure test is in order here. You could have a leak in the radiator that only spews water in a tiny stream, only at slightly elevated/heat sink temps, and streams it right at the front of the water pump, making it look like the leak is from the weep hole. This is more than just bad water pumps. Sometimes the tension clamps weaken with years worth of heat cycles. This happened to me. I was losing coolant, and there was never a drop anywhere. Had to add coolant every month. Then I found one of the tension clamps that had lost some of its clamping strength. New conventional clamp, no more leaks......
Old Sep 30, 2023 | 12:26 PM
98CorvetteTas
Cruising
I wish I could have left my factory pump in place but unfortunately it was done when I had it replaced. My reservoir has no leakage anywhere near it and the drip distinctly comes from the bottom of the pump. I'm starting to grow suspicious that the harmonic balancer may be going bad and ruining pumps as a result.
Old Sep 30, 2023 | 12:42 PM
  #33
98CorvetteTas
Cruising
I'm almost certain that ADO-251-744 is the pump on my car right now which is not a remanufactured pump according to Delco. The NAPA pumps were not so surprising to see fail but the failure of this specific pump has me wondering of maybe there's something else causing their failure. The belts have always come off before any coolant gets released but unfortunately by then they're already ruined from driving with the pump pissing out fluid.
Old Sep 30, 2023 | 12:43 PM
  #34
98CorvetteTas
Cruising
Do you know the parts number for the pump and if it requires any modification of the pulleys to work? I would definitely try one of these units out as long as they do not require any modifications.
Old Sep 30, 2023 | 01:02 PM
  #35
98CorvetteTas
Cruising
If any of you guys have any recommendations for high quality, performance-oriented water pumps for the C5 let me know. I'm willing to try another mechanical or an electric one at this point.
Old Sep 30, 2023 | 04:28 PM
  #36
grinder11's Avatar
grinder11
I can't remember the part number. I bought it around 2009. No modifications to anything. Just bolt on and play. As for any part#, you'll have to ask Jegs, Summit, or Edelbrock. Edelbrock phone# is: (800) 416-8628.
Old Sep 30, 2023 | 05:17 PM
  #37
AJ Powers's Avatar
AJ Powers
Could it be over pressurizing ?
Maybe get reservoir cap tested/replaced...
I just replaced my reservoir and it came with a higher PSI rated cap. I opted to leave the original lower PSI cap on.
Just a thought.
Old Oct 1, 2023 | 01:40 PM
  #38
grinder11's Avatar
grinder11
Just a thought.
He mentioned he's replaced the cap, so.....
Old Oct 1, 2023 | 01:42 PM
  #39
grinder11's Avatar
grinder11
Actually, NAPA stuff is usually pretty decent. Has to be, because its usually more expensive, too......
