Front Lower Ball Joint torque procedure
ball joint torque procedure in the Haynes manual. Step 2 and Step 3. If I tighten an additional 210 degrees I'm WAY past 41 ft lbs. After the 210 degree crank am I supposed to brake it loose, then do step 3, torque to 41 ft lbs? Factory original ball joint and nut. No cotter key. TIA.
* Install the lower control arm ball joint stud nut;
* Tighten the stud nut to 15 lb/ft to seat the ball joint stud;
* Turn the ball joint stud nut an additional 210 degrees;
* Check the ball joint stud nut for a minimum final torque of 41 lb/ft.
