starter relay??
Old Oct 6, 2023 | 05:36 PM
kennedy759's Avatar
kennedy759
Default starter relay??
does my 1997 have a starter relay? A few years ago I replaced the ignition module when some of the accessorys did not all come on immediately, replacing it fixed it, now for a while when I go to start it starter does not engage, Turn the key off and try again it fires right up, but now its getting worse, bad starter relay or what?,
Old Oct 6, 2023 | 06:03 PM
mmartinez's Avatar
mmartinez
Your car does have a starter relay, it is most often called the TDR "Theft Deterant Relay". The TDR is located above the BCM in the passenger footwell area behind the toe board. It is the relay that sends 12v to the starter solenoid to energize the starter.
Old Oct 6, 2023 | 08:51 PM
kennedy759's Avatar
kennedy759
thanks, got the relay off, but the potter brumfield part number 12077867 is for a 1995-96 corvette?? any ideas?
Old Oct 6, 2023 | 09:24 PM
mmartinez's Avatar
mmartinez
I would just ask for a 1997 TDR at your local autoparts store, could be that it's the same relay used in the c4 corvette.
Old Oct 14, 2023 | 12:19 PM
helphos's Avatar
helphos
Don't ignore your ignition switch as a potential culprit. I replaced my starter when I was having starting problems, but that didn't fix it. A new ignition switch did the trick.
To starter relay??
