2001 Engine delayed gauge action and Start
Old Oct 16, 2023 | 07:02 PM
seeyaracer's Avatar
seeyaracer
Default 2001 Engine delayed gauge action and Start
Upon turning key to on and engine start gauges and radio have delayed action. turning key to start may have no action or slight engine bump or crank. Back to off and then to on with a delay for gauges to cycle and then to start position starts the engine,
Old Oct 16, 2023 | 11:52 PM
ref772's Avatar
ref772
Grounds? Bad switch? ECM?
Old Oct 17, 2023 | 12:15 AM
mmartinez's Avatar
mmartinez
Have you checked your battery cables making sure they are clean and tight.
Old Oct 22, 2023 | 06:15 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ALWAYS, ALWAYS Check the condition of your battery cables first!!. Clean and tight (11 ft/lbs) If that's not the issue, Ide suspect the ignition switch and or a poor connection inside the ignition switch female connectors!.
Look for spread female pins inside those ignition switch connectors.
To 2001 Engine delayed gauge action and Start
