Door lock issue
Oct 20, 2023 | 12:16 PM
Door lock issue
I can not unlock the passenger door neither with the fob or interior switch, although I can lock it without problems
Oct 20, 2023 | 01:00 PM
St. Jude Donor '21-'22
You may need to call a locksmith. Good luck! Sorry I couldn't be of more help.
Oct 20, 2023 | 01:04 PM
Check the Solenoid and see if it is working properly . You will need to pull the door panel but it is easy to see what is working or not.
GM solenoids are famous for failing only locking and not unlocking.
I assume it will unlock manually if you use the lock on the handle?
Oct 20, 2023 | 02:00 PM
Quote:
Originally Posted by
captain vette
On both the drivers door and the passenger's door? If only one, it may be the switch.
Oct 20, 2023 | 04:26 PM
rrwirsi
both doors
Oct 20, 2023 | 04:28 PM
hyperv6
yes I can unlock it using the manual unlock handle
Oct 20, 2023 | 05:35 PM
90% chance that the door control module for the passenger door has a failed relay in it. This is the most common issue with the lock function.
The relay can be replace with a bit of effort. The circuit board has a silicone like coating on it to protect the components from moisture. There are threads here on doing the repalcement.
Gary
Oct 20, 2023 | 05:56 PM
ABS Fixer does door modules too in case you don't want to source the relays and do the soldering yourself.
Oct 21, 2023 | 08:46 AM
captain vette
Ok this tells us the linkage is working.
Now you need to check the power to the Solenoid in the door that actuates the lock open and closed. You need to see it is getting power both ways. If it is the solenoid is likely bad.
Between 2000-2008 GM has solenoid issues in many of their cars. Normally they die one direction.
I had to replace all 4 in my Malibu.
Oct 23, 2023 | 12:30 AM
Moved to C5 Tech for further discussion.
