AC Delco Spark Plugs
Old Oct 26, 2023 | 04:09 PM
JDiv48's Avatar
JDiv48
Default AC Delco Spark Plugs
Guys I need some help on the correct AC spark plug # for a new to me 2003 convertible with 38 k miles. The owners manual calls for 41-974. Looking at that number the audit trail gets murky and ambiguous in a hurry. 41-110 41-985 41-962. Intended purpose of the car is probably not much more than take my wife of 55 years to the ice cream joints on nice days. I'm not running NKGs. Thanks guys. .
Old Oct 26, 2023 | 04:55 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Old Oct 26, 2023 | 05:06 PM
redzg's Avatar
redzg
41-974 were double platinum, apparently discontinued. Many — and I’m one of them — found several plugs where the ground strap platinum pad was missing in action, leading to huge plug gaps. 41-962 is also double platinum. Pass
41-110 & 41-162 are iridium, with very small diameter center conductors — hard, hard material that lasts very long, and the small diameter produces ignition at lower voltages. The go to plug type for a stock motor.
Interestingly, Summit’s fitment guide does NoT list the 41-110 as suitable for the LS6
Old Oct 26, 2023 | 05:19 PM
redzg's Avatar
redzg
Forgot to ask: why no NGK? Previous bad experience?
Curious because you are also going to need new wires — OEM are well known to come apart on the first plug change.
Go to wires have been GM high performance, 89017270, but many options work just as well, some for very good prices.
Old Oct 26, 2023 | 06:04 PM
JDiv48's Avatar
JDiv48
Thanks C5.
That's what I was thinking .
Old Oct 26, 2023 | 10:23 PM
silverbullet98c5's Avatar
silverbullet98c5
Just installed 41-162 and Blue Streak Performance wires from RockAuto on mine. Runs great!
Be generous with your time allotment to change them, you’ll need some patience.
Old Oct 27, 2023 | 12:12 AM
JDiv48's Avatar
JDiv48
Silver, any words of wisdom on the left rear under the brake booster and vacuum lines? This is going to be a winter project so I will have days to complete the job..
Old Oct 27, 2023 | 12:33 AM
jdmvette's Avatar
jdmvette
Night Owl for life
just be careful where you get your plugs. i bought some "NGK" plugs from amazon and they were counterfeit fakes...lesson learned.
bought the real NGK plugs from o'reilleys and it resolved all my other car's issues.
Old Oct 27, 2023 | 07:32 AM
bookyoh's Avatar
bookyoh
There is a Snap-On double swivel spark plug socket. It is very helpful for removing the rear most spark plugs. I do not know if any new ones are available but there are used ones out there.
Old Oct 27, 2023 | 03:40 PM
JDiv48's Avatar
JDiv48
Thank goodness I've got one of those from the old days..
Old Oct 29, 2023 | 11:34 AM
redzg's Avatar
redzg
The Gearwrench magnetic swivel worked on all eight of mine. I may have used an additional extension on seven, do not recall for certain, but the swivel socket worked a treat for very few dollars. I also very much liked the Lisle spark plug boot pliers. Both had been recommended by other forum members.
Amazon Amazon
Amazon Amazon
Old Oct 29, 2023 | 03:34 PM
captain vette's Avatar
captain vette
41-162 Iridium is what you want gap’s.040 don’t thrust the owner manual at .060 that was good for the old factory plugs
Old Oct 29, 2023 | 07:06 PM
silverbullet98c5
JDiv48 -
I used this youtube as a guide:
Double offset Lisle spark plug pliers are a must for the wires: https://www.rockauto.com/en/moreinfo...000744&jsn=773
I started out just grabbing the rubber, but switched to lightly pulling on heat shield grabbing around the outside. Grabbing the heat shield helped pull them out easier (and didn't deform the heat shield).
The video shows how you can remove the brake booster line to get a bit better access to the rear driver's side for installation/removal.
For the plugs, agree with the above a good plug socket is needed, and a lot of extensions/patience. Particularly for installing the wires and making sure they are seated properly.
Hope that helps.
Old Oct 30, 2023 | 09:00 AM
Andwen's Avatar
Andwen
8th Gear
I installed a set of 41-162 a few weeks ago and they have been perfect. Stock 2002 base.
Old Nov 20, 2023 | 01:12 AM
douglasjre's Avatar
douglasjre
Originally Posted by C5 Diag
41-110.
The 162 plug I put in recently works well. After researching I found this this is a hotter plug. I'm surprised since there's less detonation now.
Old Nov 22, 2023 | 09:15 PM
douglasjre's Avatar
douglasjre
What are the benefits of the 110 plug?
Old Nov 22, 2023 | 09:55 PM
JDiv48's Avatar
JDiv48
Originally Posted by Lenny72
41-110 nothing else
Can you elaborate on that>
To AC Delco Spark Plugs
