Dreaded 02 codes with Longtubes
Old Oct 29, 2023 | 06:57 PM
2001Z's Avatar
2001Z
Default Dreaded 02 codes with Longtubes
Hello everyone, as you can tell I am a new member here! I have recently transitioned from a SLP ZL575 to a H/C C5Z. The seller did not disclose the CEL issues and I was lucky enough to get 5 miles from his house prior to them popping on.
I am getting the normal P0154/P0134 codes. The car has LG Pro longtubes. This weekend, I replaced the front 02 sensors with new Denso (rear) 02 sensors and corrected the 02 routing. The PO had run the front 02 to opposite side harnesses.
Immediately, the car seemed to idle slightly better and returned better fuel mileage. It also appears to be running a bit richer. I am noting this by the clearly more present rich smell. This initially led me to believe I had fixed the issue. However, it has returned. The most odd part to me is that it sometimes take 30-40 miles for the codes to appear. I am at a loss from here. Where to next? Potentially tune parameters being too “tight?”
Thank you in advance for any assistance.
Old Oct 29, 2023 | 10:19 PM
oktx's Avatar
oktx
Was it tuned after the headers were installed?
Old Oct 30, 2023 | 06:18 AM
2001Z's Avatar
2001Z
Oktx,
I know the car was tuned, but I do believe the car had a cam and supporting mods installed and tuned at the same time, with the headers being added later. Could it be a parameter thing? The car runs amazing, but I can stand a pesky dash light.
Old Oct 30, 2023 | 07:21 AM
oktx's Avatar
oktx
Originally Posted by 2001Z
Oktx,
I would think the car would need tuned for the headers.
Old Oct 30, 2023 | 10:54 AM
2001Z's Avatar
2001Z
I don’t totally disagree, but I do know it does have a tune. Per the PO, it was tuned prior to the LTs being installed. However, there are countless members that add LTs and don’t get their car tuned. Is it possible the present tune has that sensitive of parameters?
Old Nov 1, 2023 | 11:08 AM
vettenuts's Avatar
vettenuts
I would trace the wiring. Those codes are showing no O2 activity so any data from the sensors aren't reaching the ECM. Also check for any vacuum or exhaust leaks. I would also put the original O2's back in with the correct side wiring, them move on from there. When you changed the O2 sensors and the wiring you made two changes as once so diagnosis becomes harder and you don't know if you eliminated an issue or fixed one and created a second.
Old Nov 1, 2023 | 12:08 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
LG also recommends running rear O2s on the front using an adapter harness. Trace it to see if any wires were burned, connections melted, BTDT. I've used p clamps using the tunnel shield bolts to route wires.
Old Nov 1, 2023 | 12:36 PM
2001Z's Avatar
2001Z
I should clarify - when I swapped 02s this past weekend, I corrected the PO’s routing as he had the sides swapped.
I am still getting the same codes as prior, being P0134 and P0154. I have dropped the car off at MTI racing in hopes they can track down the issue. I will update the thread as I receive updates.
To my eye and limited knowledge, all wiring looked fine.
Old Nov 2, 2023 | 05:41 PM
lionelhutz's Avatar
lionelhutz
You have the rear O2's plugged into the front O2 spots with adapter harnesses, right?
FYI, using front or rear sensors doesn't make a difference functionally. But some of the headers put the primary sensors so far away that the wires on the front sensors won't reach the plugs hence the recommendation to use rest sensors with adapter harnesses.
Old Nov 2, 2023 | 09:28 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
The reason given for adapting the rear O2s to the front was the rears supposedly came with a better heater circuit.
Old Nov 2, 2023 | 09:31 PM
Supercharged111's Avatar
Supercharged111
I tried that, but repinned the PCM to skip an adapter harness. Had a slow switching code from day 1. Somehow I think both must have been junk from the get go as the rears won't throw a code for slow switching with a stock tune. They were sooty when I pulled them, swapped back for the fronts and all is well again. Isn't the rationale that the heaters are more robust in the aft sensors and thus work better with long tubes? Either way OP's issue is something different. I'd have to wonder what the 2 sensors share? No activity detected from both should clue a guy in to what's gone wrong. The fronts are as they are and the rears are flipped, i.e. they cross over so left is right and right is left.
Old Nov 3, 2023 | 01:27 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Check that the fuses for the 02 heater circuit. They may be blown. That could cause your problem. Also you should be able to turn the key on with the engine not running as feel if the warm up. A cheap obd2 scanner will help immensely with trouble shooting this. As you will be able to determine what's going on with them.
Old Nov 3, 2023 | 06:17 PM
2001Z's Avatar
2001Z
What is traditionally a cause for the fuse to blow? I have seen several forums referring to blown fuses continually blowing.
I believe my codes are purely from slow response from the front 02s. I have adapters in the car to run the rear 02s up front. The car runs great and pulls hard, I just can’t stand a CEL.
Old Nov 3, 2023 | 06:57 PM
Supercharged111
Then you're having the exact same problem I did. For the entire time I ran rear O2s as fronts I had a slow switching code for both banks. Those codes disappeared for good when I put the original fronts back in as fronts.
Old Nov 3, 2023 | 11:48 PM
2001Z's Avatar
2001Z
Interesting… I am in limbo while the car is at MTI. I will likely suggest they replace the current 02s in the front bungs with OE fronts. Bummer as I just replaced them, but I’d rather not see the pesky light on. I will update the forum as MTI Racing provides me updates on the car.
To Dreaded 02 codes with Longtubes
