Mini tubs?
Old Jan 23, 2003 | 10:51 AM
T-MAN's Avatar
T-MAN
Default Mini tubs?
Anybody mini tub there vette?thinking of doing it so i can put a 335/30/18 or 345/30/18. any info from someone thats been through it.
Old Jan 23, 2003 | 11:56 AM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Default Re: Mini tubs? (T-MAN)
Didn't you mean a 345/30/19 ? If so, I am also interested. I'd also like to know about max wheel size as I'm looking into 13" x 19" all inside the wheelwells. I think NoMercy has this setup. Any others? Benelliwang-Your Dr. friend has 345's doesn't he? Hopefully someone will step in soon as I have to order in the near future.
Old Jan 23, 2003 | 12:07 PM
T-MAN's Avatar
T-MAN
Default Re: Mini tubs? (xtream1)
just ordered mini tub from xtreme motorsports,cant put 345/30/18or19 lots of modifying says mini tub only allows for a 335 tire on a 12 inch rim anything bigger cant do.dont let anybody tell you that you can.
Old Jan 23, 2003 | 12:18 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Lingenfelter's site says their mini-tub allows placement of a 345 tire.You might want to check this out? :cool: :cheers:
Old Jan 23, 2003 | 12:38 PM
Edge 904's Avatar
Edge 904
Default Re: Mini tubs? (binksZ06)
345/30/19's are possible with LPE's mini-tub.
Old Jan 23, 2003 | 12:41 PM
kromberg's Avatar
kromberg
Default Re: Mini tubs? (Edge 904)
What wheel offset is used with those 19s?
Keith
Old Jan 23, 2003 | 12:45 PM
Edge 904's Avatar
Edge 904
Default Re: Mini tubs? (kromberg)
Don't know the offset. Give LPE a call or email ZDog. He's running 345/30/19's on HRE 541's with an LPE mini-tub.
Old Jan 23, 2003 | 12:46 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I'd also like to know the offset and back spacing for 18x12s. :yesnod: I have the Forgelines off of my C4 that I could widen the rears to get 18x12. :D
Old Jan 23, 2003 | 01:03 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Mini tubs? (93Polo)
93Polo- Iwas told that 18x12 with stock z06 offset results in 9.5" backspacing. On a Z06 vendors suggest reducing to 9 3/8' backspacing which changes offset by 1/8".Hope this helps. :cheers:
Old Jan 23, 2003 | 03:17 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Thanks interesting the change on backspacing. Is this for the rear brakes vents?
Old Jan 23, 2003 | 03:57 PM
kromberg's Avatar
kromberg
That does not make sense :confused: The whole point of tubing a car is to increase the back spacing.
Keith
Old Jan 23, 2003 | 04:19 PM
HIGHRPM's Avatar
HIGHRPM
BFG is releasing a 345/30/18 drag radial in the next 90 days.
Old Jan 23, 2003 | 08:15 PM
Dave00C5's Avatar
Dave00C5
I have seen a 345 tire on a LPE car when picking up mine. Don't remember if it was 18 or 19 though?
Old Jan 23, 2003 | 08:34 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Keith
I think he meens less backspacing than the Coupes. 9 3/8 bacspacing is almost the total width of a normal C5 rear wheel. I plan on adding the Z06 rear brakes ducts and own a FRC therefore am very curious about the reason for the change.
Lamar
Old Jan 23, 2003 | 09:13 PM
xtream1's Avatar
xtream1
I think NoMercy is currently running a 345/30/19 on a 12.5" rim. Anyone volunteer to contact him for confirmation and clearance issues?
Old Jan 23, 2003 | 09:31 PM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
I helped mini tub my car last weekend. The whole interior was removed to protect it from the mess. Used a mini grinding wheel to cut in the new tubs. What a dusty mess. The mechanic who did most of the work said he wouldn't do it again for less than $2000 installed. :eek:
Old Jan 23, 2003 | 11:38 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: Mini tubs? (Rippied Z06)
Rippied, what size tires are you going with and did you use a kit?
I am just about certain No Mercy has 345/30 19s.
To Mini tubs?
Old Jan 24, 2003 | 12:58 AM
boblackhardtop's Avatar
boblackhardtop
For 18x12 Max. backspacing is 9.125. For 19" you can extend to 9.5 so you have to add .125 to frontspacing to give you 12.5"
Old Jan 24, 2003 | 03:26 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Mini tubs? (boblackhardtop)
I've been considering this as well. I saw a few of them up at LPE, but i've forgotten how great they look. Can someone provide some photos of their finished work? I need inspiration. :cool:
Old Jan 24, 2003 | 01:42 PM
kromberg's Avatar
kromberg
Default Re: Mini tubs? (BQuicksilver)
ttt
