Cracked block or headgasket?
Old Nov 1, 2023 | 08:00 AM
Remy_'s Avatar
Remy_
Cruising
Default Cracked block or headgasket?
I disassembled my 2003 z06 and the head gasket and block look okay yet white smoke is coming out of the exhaust and there is coolant in the oil. Is there a common location where these blocks crack that I could check?
Old Nov 1, 2023 | 09:10 AM
Dads2kconvertible's Avatar
Dads2kconvertible
A compression or leak down test should narrow it down to the right cylinder.
Old Nov 1, 2023 | 09:35 AM
grinder11's Avatar
grinder11
LS1/LS6 blocks arent known for cracking. Do you know the history of the car? I'm guessing here, but my money is on the head gasket or warped heads. Was it used at the track/drag raced/HPDE? But if the car was in a Northern state with inadequate antifreeze, perhaps it froze? History is key......
Old Nov 1, 2023 | 11:23 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
overheating, bad antifreeze can damage the block.
Could be a head gasket or the head bolt holes can crack in the block if the threrads were not cleaned out before reinstllation or a head stud was over tightened into the block
Old Nov 1, 2023 | 11:55 AM
vettenuts's Avatar
vettenuts
Need more information, is the engine stock or modified?
Old Nov 1, 2023 | 01:14 PM
3sACROWD's Avatar
3sACROWD
It could be a cracked head. Did you pull both sides already? If not, why did you pull the side you did? Look at the top of the pistons. The cylinder with the leak will be clean compared to the rest,
Old Nov 1, 2023 | 02:05 PM
Remy_'s Avatar
Remy_
Cruising
can I do that with the heads off?
Old Nov 1, 2023 | 02:09 PM
Remy_'s Avatar
Remy_
Cruising
Single owner with 23,000 miles. Daily driven during those miles but never taken to the track.I do not know the antifreeze history. I have it apart and have been inspecting the block and gasket however I cant find the exact cause.
Remy_'s Avatar
Remy_
Cruising
The head has never been opened up so I dont think its the bolt holes.
Old Nov 1, 2023 | 02:38 PM
Dads2kconvertible
You didn't quote the posts you replied to so I'm guessing a little here.
You were seeing white smoke so you pulled both heads and can't find a crack. That's not exceptionally unusual, the crack(s) can be almost invisible to the naked eye. Magnaflux used to be THE process to find cracks, I don't know how it's commonly done today. Back in the day the components in question went to the machine shop and they had the Magnaflux equipment.
93Polo suggested the head bolt holes could crack IN THE BLOCK so if you have the heads off now you might as well check there. You don't know the history and it's a known failure point.
No, you can't do a compression or leak down with the heads off. You CAN look at all eight pistons. Does one of them look clean compared to the others? That is the one that has coolant entering. That coolant turns to steam when the pressure drops during the suck and blow revolutions of a four cycle engine and that steam will probably clean any deposits off the face of the piston.
Old Nov 1, 2023 | 05:06 PM
Remy_'s Avatar
Remy_
Cruising
I pulled both sides and all cylinders are equally dirty.
Old Nov 1, 2023 | 06:07 PM
grinder11's Avatar
grinder11
Can't magnetic particle inspect (magnaflux) aluminum. But there is a special dye they use, but I'm not familiar with what kind of dye, or with the process.
Old Nov 1, 2023 | 09:54 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Agreed, I'd be looking at spark plugs and if one chamber in the head and top of the piston on one looks cleaner than the others.
If the heads have not been off recently, chances are low of this. But, yes if there is gunk in the head bolt holes and you torque it down, the block can crack around the thread causing coolant to get where it doesn't belong.
Old Nov 1, 2023 | 09:59 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Odd, with the heads off, I'd have a machinist check the heads over well, pressure test, look at guides, valve stem seals, and deck them for cleanup. Verify a valve isn't bent. A valve can have a slight bend and seal for a while, granted if a valve was bent you should see marks on a piston.
Old Nov 2, 2023 | 09:54 AM
3sACROWD's Avatar
3sACROWD
I think we need more of the story. What made you start to investigate? What events led up to the identifying the white smoke and coolant in the oil? What kind of exhaust do you have (stock or aftermarket) Was the white smoke from one or both sides? Even with the stock H pipe, one side should be significantly heavier vs the other. Was there any engine work, track day, driven spirited? Given the fact that you're not seeing one cylinder much cleaner than the others, is confusing and I'm wondering if the white smoke is totally separate from the coolant in oil. The white smoke might not be relevant as it could be moisture in the exhaust and was identified after finding coolant in the oil. If this were the case, the issue could be further down in the block such as a water jacket leak. Maybe test the coolant to see if there is evidence of exhaust leaking into the coolant.
Old Nov 2, 2023 | 11:37 AM
Bobbo76's Avatar
Bobbo76
Veteran: Canadian Forces
MagnaFlux isn't going to work on aluminum. Liquid dye penetrant would be the technique to use for this. Normally the components would be "tanked" first to remove contaminants.
Old Nov 2, 2023 | 08:08 PM
Prop Joe's Avatar
Prop Joe
Like 93 polo said. Look at the chambers and spark plugs of all cylinders. Look for... One of these things is not like the others....
Find that one odd one and you found the cylinder/area that was leaking. Now that it is apart and you found the offending cylinder being different, look closely for a crack in the head/block(try a magnifier and a bright light) or bad gasket (usually between cylinders).
Nonferrous/aluminum parts are checked for cracks with penetrant. Two common methods, either visual penetrant or Florescent (black light) The process is only as good as the prep, needs to be clean. In a pinch if the area is dry you can use WD-40 as a penetrant as its capillary action will seep into a crack. The capillary action is the foundation of penetrant inspection for cracks on nonferrous parts.
To Cracked block or headgasket?
Old Nov 6, 2023 | 07:56 AM
Remy_'s Avatar
Remy_
Cruising
It started to run hot and it had white smoke coming out of the back. it also had low coolant. I dont remember if one side was stronger than the other. It has a stock Z06 exhaust. There has been 0 past engine work and it was daily driven with only a little bit of spirited driving. It only has 23k miles on it and that is what has me confused as to why it is giving me trouble.
Old Nov 6, 2023 | 12:49 PM
Beast's Avatar
Beast
A car can have trouble anytime anywhere. Good luck in your project. Your this far into it. Pull the block, send it out to a machine shop, and say 383 forged stroker please.
Old Nov 6, 2023 | 06:47 PM
grinder11's Avatar
grinder11
I LIKE the way Beast thinks!!!
