Just adding some info on mine. Pilot bearing destroyed as well. Going to do a rebuild on the torque tube as well as I can't remember if it was done when the DSS carbon shaft went in.
So, update to an update. When the prop shaft came out of the tube. A bunch of the bolts were literally hand tight. Some backed out.
I'm sure that caused the wobble that ate the pilot bearing.
I'm not going to name names. But the DSS fiber shaft was put in by a pretty well known local shop.
I'm not thrilled this torque tube is out the second time in under 5k miles.
