Low Oil temp on DIC?
Old Nov 5, 2023 | 02:06 PM
oktx's Avatar
oktx
Default Low Oil temp on DIC?
I was scrolling through the gages on my car and and oil temp said low. Bad sensor I hope?
Old Nov 5, 2023 | 06:23 PM
mmartinez's Avatar
mmartinez
Most likely, the oil temperature sensor output goes directly to the gauge, unlike some sensors that input to the pcm, and then sent to the gauges.
Old Nov 5, 2023 | 07:02 PM
bookyoh's Avatar
bookyoh
I got that warning once but it was on a 0 degree winter day.
oktx's Avatar
oktx
I found a code for it. It was history, I cleared it, but haven’t driven it yet to see if it works. Thank you
Old Nov 6, 2023 | 07:46 PM
oktx's Avatar
oktx
I drove the car today for about 30 minutes. The code came back. I guess the sensor has failed or my headers melted the wires.
Old Nov 6, 2023 | 09:57 PM
Supercharged111's Avatar
Supercharged111
I roached my plug on the header and car throws the same code, my guess is it's showing an open circuit for you.
Old Nov 6, 2023 | 10:09 PM
ThomasR's Avatar
ThomasR
I believe the DIC displays low below 15*. If it reads low it never reads at all until you shut the car off for a few minutes and restart the car.
Old Nov 6, 2023 | 10:21 PM
oktx's Avatar
oktx
I’ve read two old threads that said when their headers were installed the wires on the sensor were pulled out or damaged. Im starting to think this is what happened. Yes it show B1543 open circuit.
Old Nov 7, 2023 | 07:28 PM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
Could be a bad sensor. Could also be bad wiring, especially if you have headers. The wiring runs REALLY close to the headers, and if it gets too close the heat can destroy the wiring. The sensor is located on the oil filter housing. Get under the car, find the sensor and trace the wires up. If the wires are undamaged, replace the sensor. If the wires are damaged, repair the wires before throwing a sensor at it.
Old Nov 10, 2023 | 02:51 PM
oktx's Avatar
oktx
Update! The sensor connection was melted/broken.
To Low Oil temp on DIC?
