Headlight problems, please help!
Old Nov 14, 2023 | 07:12 PM
mkw777's Avatar
mkw777
3rd Gear
Default Headlight problems, please help!
I had the famous bump stop problem with the driver's side headlight and replaced the bump stop. All worked fine. Today I drove to the store and when I turned off the lights, the driver's side stayed up but turned off and the passenger side went down. I turned the lights back on and it came on but stayed down but the passenger side popped up and was on. Now when I turn the switch off, the driver's side turns off but stays up and the passenger side goes down like it's suppose to. Any help is greatly appreciated!!
Old Nov 14, 2023 | 07:45 PM
jdmvette's Avatar
jdmvette
Night Owl for life
If they are still your OEM 20+ originals, get some new motors in there and they'll operate smooth like butta once again
https://www.ebay.com/itm/28407138941...Bk9SR5KI-4b6Yg
Old Nov 14, 2023 | 08:40 PM
mkw777's Avatar
mkw777
3rd Gear
Thanks! I just ordered a motor from Amazon. If that don't work, I'm going to replace both lights with the C6 style and forget about the pop-up lights!!
Old Nov 14, 2023 | 09:24 PM
PetrofMII's Avatar
PetrofMII
If the problem recurs, you may need to insert washers at the three bolts holding the motor to the frame to push the motor away a bit. GM had a SB out on this. I think Rodney Dickman Automotive sold a set, or you can buy some appropriate washers from your local hardware store.
Old Nov 15, 2023 | 03:50 PM
jdmvette's Avatar
jdmvette
Night Owl for life
^ not in every case. My OEM motor housings cracked and the motor itself would rotate inside it's own housing which caused the wormgear to not come into contact with the gear teeth so the headlight wouldn't raise.
These things do wear out over 20+ years and they're very easy to replace with new parts that'll last you another 20 years before you have to worry about them again
Old Nov 15, 2023 | 04:00 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Don't talk to me about hypotheticals when I am the 1 of 1000 right here buddy.
**** breaks down, so you deal with it and replace the parts. It's not a big fkn deal
To Headlight problems, please help!
