Changing Fan Set Points?
Old Nov 21, 2023 | 02:26 PM
Choreo's Avatar
Choreo
Default Changing Fan Set Points?
If I want to reprogram when my radiator fans come on and go off, is that something a local mechanic can do with something like a Tech II? If so, what would be an average price?
Old Nov 21, 2023 | 06:22 PM
jcgunn's Avatar
jcgunn
You can do it yourself with a handheld tuner like a Hypertech or Diablo Sport
Old Nov 21, 2023 | 06:35 PM
captain vette's Avatar
captain vette
good, but is it possible to to it with a tech 2
Old Nov 21, 2023 | 06:37 PM
Choreo's Avatar
Choreo
Is this the unit you are referring to?
https://hypertech.com/products/max-energy-32500
Old Nov 21, 2023 | 06:41 PM
ThomasR's Avatar
ThomasR
No.
Old Nov 21, 2023 | 06:47 PM
Choreo's Avatar
Choreo
Originally Posted by ThomasR
No.
So, most professional mechanics do not have this capability?
Old Nov 21, 2023 | 08:11 PM
ThomasR's Avatar
ThomasR
The Tech 2 is a scan tool not a tuner.
There are very few changes you can make. You can remove the F45 option on Corvette, program pass key2 keys faster on those cars(10 minutes vs 30) and reprogram/update modules using tis2000. For F and Y bodies you could request programming change for rear gear changes to correct the speedometer. That's about it.
Old Nov 21, 2023 | 08:29 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
One way is with a HP tuner, and the credits are 50.00 per vehicle ??
Old Nov 21, 2023 | 08:51 PM
Choreo's Avatar
Choreo
What is it showing me on this page? https://hypertech.com/products/max-energy-32500
What do the "greyed out" settings represent?
This says:
Cooling Fan Adjustments
  • Cooling Fans Stock, 180 degrees F, 195 degrees F
From other videos I have watched on the C5 they say stock fan settings are
226 degrees F - Low fan starts
235 degrees F - Hi fan starts
Exception - 185 degrees F Low fan starts w/AC on under 35mph
Old Nov 21, 2023 | 08:57 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
This says:
this is close to correct, Mine come on at low 198, high 210
Old Nov 22, 2023 | 06:28 AM
Moved to C5 Tech.
To Changing Fan Set Points?
