Charging system failures
Old Nov 26, 2023 | 03:14 PM
Travis Armstrong's Avatar
Travis Armstrong
Default Charging system failures
Is my new/rebuilt alternator suspect?
Car stalled, jumped started/drove home. Volt meter test across battery with engine running sub 12vdc.
Replaced alternator with rebuilt. Charge battery overnight. Parts store tested battery and new alternator. Alternator and battery passed test.
Headlights are now pulsing and random misfires popping up.
Did a voltage drop test from alternator frame to neg battery post engine running (54millivolt)
Unloaded engine running 13.8v at battery posts
Loaded engine running 13.3v at battery posts
Starts easy with no lag.
Battery is 5 years old but tests as good.
Why the pulsing lights and misfire?
Old Nov 26, 2023 | 04:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like your charging system is working OK. You are getting a LOW VOLTAGE at some where other than the charging circuit.
NOTE! You could be experiencing abnormal voltage input OR a shitty GROUND PATH.
Start with measuring the voltage on the circuit fuse for all of those individual circuits. On top of each fuse, are TWO TEST POINTS. Measure each test point to a proper ground. Look for full battery voltage on each fuse test point. I personally do a LOAD TEST with an incandescent lamp on each fuse while measuring circuit voltages. When you load down that fuse with a higher current device (test lamp), you should not see a significant voltage drop!
Another failure point is the B+ feed input for each fuse block. I personally remove the nut for the block, clean the terminals and properly tighten the nut for a proper connection. .
Your lights are on a hot at all times circuit. That would lead me to suspect a POOR GROUND PATH.
If it were ME, I would Inspect & clean ALL the under hood chassis grounds and ground blocks. I'm the person who likes to SEE THE SMOKING GUN that caused the issue. You can use a volt meter to read across the ground terminal to a very clean chassis point or battery ground terminal and see if you read ANY VOLTAGE DROP. The more voltage drop you see across a ground point the worst condition that ground point is in. Note, you may need to switch to the millivolt scale to measure some voltage drops. I would start in a scale that reads 0-20 VDC and then work to a lower scale..
When you turn your ignition switch to ON/RUN, it supplies power to all of the HOT IN ON/RUN powered devices. Those modules (PCM, BCM etc..) are powered by TWO power sources. ( HOT AT ALL TIMES & HOT IN ON & RUN) IN MY HONEST OPINION, I would load test and voltage test both the Hot in run and Hot at all times fuses.
Bill
Old Nov 26, 2023 | 04:14 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Did you test your old alternator?
Read the sticky posts, the OEM alternators have something different about them that replacements often don't have. Bill probably knows what that is.
I'd try and get your original one back in case you end up needing to rebuild it instead of replace.
Old Nov 26, 2023 | 04:55 PM
Travis Armstrong
Bill
I should note that the headlights do not pulse when key on/engine off.
With key on/engine on the headlights pulse until you bring the rpms up high.
Old Nov 26, 2023 | 10:47 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I should note that the headlights do not pulse when key on/engine off. I
Sounds like a voltage regulator issue. C5 needs Valero regulator in alternator. Alternator will test good but not work in C5. Make sure the replacement Alternator is compatible with your car.
Old Nov 27, 2023 | 11:33 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
With engine running at 2500 RPM and electrical load on it measure voltage drop from alternator B+ to battery positive...should not be more than 0.5 volts...normally around 0.2 to 0.3 volts....do the same from alternator case to battery negative...you can't do a voltage drop without current flow !!...i.e. engine off !!...pulsing lights are normally a ground issue.
Old Nov 29, 2023 | 07:53 PM
Travis Armstrong
Sorry for the confusion. I meant "battery post, engine running" and not "battery, post engine running" ya dig? 54 millivolts was the result.
Back has been acting up and I've been slammed at work. Going to do more troubleshooting very soon.
To Charging system failures
