Help Identify Noise ‘98 49k miles
I was still noticing a tapping/thumping noise and that was the rocker arm and pushrods so I had those done. Now I am still hearing this noise in the video linked below its like a fluttering/tapping when I accelerate?
There was also a noise I noticed when I was at a idling at a red light so probably idler pulley? Let me know if you might know what this is please. Thanks!
Acceleration Noise Videos:
https://youtube.com/shorts/YblTwWn9Qeg?si=QPAoZmT0V2AYQAnC
https://youtube.com/shorts/0Qp6TgsqVSY?si=xPZIchesokXNQbIr
Idle Noise Video:
https://youtube.com/shorts/2UT-So_s0Cc?si=Fy9PBEk50-cNjwPq
Having an automatic trans, your Torque Tube is ALWAYS SPINNING when the engine is running.. If I were a betting man, I would say you may have worn/defective rubber couplers or worn / noisy bearings in the TT.
I recommend getting the car in the air and using a mechanics stethoscope to listen to the rotating parts of the drivetrain and see if you can pin point the noise to a specific location. (Like the front of the TT. or in the front bell housing If you have an A4 automatic, there is a connection clamp on the input shaft of the flex plate/torque tube shaft that can come loose and make weird noises. The maintenance manual provides specs for properly tightening it.
Wish me luck! Also how much do you think a job like that would cost?Last edited by Slo.c5; Dec 5, 2023 at 06:06 AM.
