E-BRAKE POPPED!?!? WTF!
Old Jan 24, 2003 | 02:48 PM
RskyBns's Avatar
RskyBns
Default E-BRAKE POPPED!?!? WTF!
So a few times I pulled my e-brake when in park and the darn thing made this wicked pop noise. :eek: It has since happened a couple more times when engaging the brake. What is the deal? :confused: I tried doing a search and didn't come up with anything. :banghead: Thanks.
Old Jan 24, 2003 | 02:55 PM
scool93535's Avatar
scool93535
Default Re: E-BRAKE POPPED!?!? WTF! (RskyBns)
I've experienced it a few times myself. :mad Since the E break doesn't do anything I just wrote it off and don't use it. :D
I do wish they had replaced the E break with another cup holder, it would be more useful. :jester
:cheers:
Old Jan 24, 2003 | 03:00 PM
Traffic Hater's Avatar
Traffic Hater
Default Re: E-BRAKE POPPED!?!? WTF! (scool93535)
Mine has done the same thing from time to time. I think it occurs at the very end of the movement. Seems to want to go only so far before it pops!
Old Jan 24, 2003 | 03:15 PM
Jeff Jeff's Avatar
Jeff Jeff
Default Re: E-BRAKE POPPED!?!? WTF! (Traffic Hater)
There is a ratcheting mechanism in the handle on the e-brake that grabs the cable. Mine makes the same popping noise occasionally. I noticed pulling the handle gently and not in a fast jerk motion seems to eliminate the problem.
Old Jan 24, 2003 | 03:37 PM
MRCoupe2002's Avatar
MRCoupe2002
Default Re: E-BRAKE POPPED!?!? WTF! (Jeff Jeff)
I had the same problem a few times after I had the car for a few months. I switched to a slower pulling motion and the problem appeared to go away. My assumption was that when I was pulling quickly I was also pulling towards me and the popping noise was something in the console catching on the handle. Haven't heard the popping sound now for several months.
Old Jan 24, 2003 | 04:28 PM
Gash Hunter's Avatar
Gash Hunter
Default Re: E-BRAKE POPPED!?!? WTF! (MRCoupe2002)
Seems like a ongoing problem. My 98 e brake never did work, even after the dealer adjusted it three times. Each time they had the car for two days. I gave up on them. You would think after paying that much for a car the ebrake would work and the steering column would unlock when you want it to.
Old Jan 24, 2003 | 04:48 PM
Crushinator's Avatar
Crushinator
Default Re: E-BRAKE POPPED!?!? WTF! (Gash Hunter)
Just a common Corvette problem you're experiencing. No big deal. The E-brakes in these cars are Yugo quality. :U
Old Jan 24, 2003 | 04:54 PM
Waterfreak's Avatar
Waterfreak
Default Re: E-BRAKE POPPED!?!? WTF! (QuickSilver97)
Join the club. My GM mechanic said that there is nothing wrong with it. Apparently a loud sound like something is breaking is "not a problem." :crazy:
Old Jan 24, 2003 | 05:12 PM
Joe's Eray's Avatar
Joe's Eray
Happens to me too. Just one of the few C5 bugs that are in our cars.
Old Jan 24, 2003 | 10:56 PM
JAY KOCH's Avatar
JAY KOCH
Default Re: E-BRAKE POPPED!?!? WTF! (BrightRed C5 SWFL)
Don't know about the popping sound but for those of you with e-brake adjustment problems, go here for the fix. https://www.corvetteforum.com/techti...=158&TopicID=1
good luck :steering:
Old Jan 24, 2003 | 11:07 PM
batsallover's Avatar
batsallover
Default Re: E-BRAKE POPPED!?!? WTF! (JAY KOCH)
This thread is for adjusting the emergency brake "drum" at the rear wheels. I corrected this popping sound which does come from the "ratcheting" mechanism at the brake handle. I pulled back the carpet near the handle. It is secured with velcro. Then I observed the mechanism and found that it was sticking and was slow to engage. So I cleaned it with WD40 and used some leftover Mobile 1 to lubricate it. :lol: It's been over two years since the adjustment of my brakes using the tech tip and lubricating the brake handle mechanism. :cheers:
BTW, my emergency brake engages at halfway travel. :thumbs:
To E-BRAKE POPPED!?!? WTF!
