Manual Tranny - Hard to Shift
Old Dec 9, 2023 | 11:02 AM
rcoldham@comcast.net's Avatar
2nd Gear
Default Manual Tranny - Hard to Shift
Recently bought a used 2000 (C5) manual transmission (only 18K miles). Haven't owned a stick in many years, so my test drive gave me no indication of how hard I had to push to get into gear - all of them.
A friend has a 2001 (C5) stick and we were comparing notes. He suggested I drive his car to see what little effort he needs to put out to change gears. I was amazed - like a hot knife thru butter - very little effort needed to shift on his 2001.
Owners manual talks about the spring that centers the gearshift lever near 3rd and 4th. Says the spring will try to pull the gearshift towards these gears...but I don't believe this is my issue.
Looking for any ideas/suggestions on what this could be and how to overcome it. Thanks -
Old Dec 9, 2023 | 11:12 AM
yellow2007's Avatar
yellow2007
Try the simplest first......Google Anti venom mod......if that doesn't correct it at least you'll only be out by maybe $3 plus half hour labor and can then dig deeper into a possible shifter swap.....
Old Dec 9, 2023 | 12:52 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
it seems the car has set a while, I would guess the shift rod joints might be rusted ?? the lower box could also be a issue ?
Old Dec 9, 2023 | 01:35 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Good points made by the others above. I would also recommend changing the clutch and transmission fluid, especially if you don't know the service history where this was noted.
Old Dec 10, 2023 | 12:12 AM
Moved to C5 Tech.
Old Dec 10, 2023 | 10:34 AM
bookyoh's Avatar
bookyoh
You may want to look into adjusting your shifter. There are many threads and some YouTubes on “C5 shifter alignment” or similar search terms.
Old Dec 10, 2023 | 11:18 AM
Supercharged111's Avatar
Supercharged111
Is this for every gear or some more than others?
Old Dec 10, 2023 | 12:46 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
THIS is the place to start.
To Manual Tranny - Hard to Shift
