'99 C5 Error Codes
Old Dec 13, 2023 | 01:05 PM
RyanE2005's Avatar
RyanE2005
Default '99 C5 Error Codes
Got some Error Codes from my recently purchased '99 C5. Researched what all of them mean and listed them out, but not sure how to go about fixing some of the major ones. Any advice? (Codes listed below)
PCM (Powertrain Control Module)
  • P0463 H: Fuel Level Sensor Circuit High Voltage
  • P1431 H: Fuel Level Sensor 2 Performance
  • P1571 H C: Traction Control Delivered Torque Output Circuit
RTD (Real-Time Damping)
  • C1780 H C: Steering Angle Sensor Circuit Malfunction
  • C1790 H: Calibration Memory Error
BCM (Body Control Module)
  • B0605 H: Control Module Configuration Error
  • B0503 H: HVAC Front Blower Feedback Circuit Range/Performance
  • B0508 H: HVAC Rear Blower Feedback Circuit Range/Performance
  • B2578 H: Inadvertent Power Circuit
  • B2583 H: Rear Window Defogger Relay Circuit
  • B2587 H: Rear Window Defogger Switch Circuit
  • B2592 H: Rear Window Defogger Indicator Circuit
  • B2593 H: Rear Window Defogger Feedback Circuit
  • B2647 H C: Ambient Light Sensor Circuit
  • B2723 H: HVAC Blower Control Circuit
SDM (Supplemental Restraint System)
  • B0017 H: Driver Frontal Deployment Loop (Stage 1)
  • B1001 H: Option Configuration Error
  • U1000 H C: Class 2 Communication Malfunction
  • U1301 H: Class 2 Circuit Short to Battery
  • U1096 H: Loss of Communications with IPC (Instrument Panel Cluster)
HVAC (Heating, Ventilation, and Air Conditioning)
  • B0363 H C: HVAC Air Mix Control Circuit
  • B0367 H: HVAC Control Head Circuit
  • B0441 H C: HVAC Recirculation Control Circuit
LDCM (Left Door Control Module)
  • B2252 H: Heated Mirror Control Circuit
  • B2282 H: Door Lock Switch Circuit
  • B2284 H: Left Rear Door Ajar Circuit
  • B2264 H: Left Window Up/Down Control Circuit
  • U1064 H: Loss of Communications with DIM (Dash Integration Module)
RDCM (Right Door Control Module)
  • B2283 H: Heated Mirror Control Circuit
  • B2285 H: Door Lock Switch Circuit
  • B2263 H: Right Rear Door Ajar Circuit
  • B2265 H: Right Window Up/Down Control Circuit
  • U1255 H: Class 2 Communication Malfunction
  • U1016 H: Loss of Communications with PCM (Powertrain Control Module)
SCM (Steering Column Module)
No codes reported.
RFA (Remote Function Actuation)
  • C2120 H C: Antenna Not Connected
Old Dec 13, 2023 | 02:06 PM
yellow2007's Avatar
yellow2007
If the car runs fine, erases all those codes. They could be from 1999 for all you know than as you drive the car see which ones if any pop back up. Trying to tackle those many codes at once will turn you into an alcoholic..............
Old Dec 13, 2023 | 03:07 PM
smitty2919's Avatar
smitty2919
Clear all the codes and drive the car. See what remains.
That's a whole lot of random stuff to even begin taking something. And or you have some iffy grounds. Would be worth cleaning all ground locations.
Old Dec 13, 2023 | 03:40 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Service manual will really help you out Ryan.
Here is a page related to one of your codes. My manual is for model year 2000, some stuff may be different for your year.
Old Dec 13, 2023 | 08:37 PM
RyanE2005's Avatar
RyanE2005
Thank you so much
Old Dec 13, 2023 | 11:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
STOP THE INSANITY!!!!
Just ERASE ALL of them and start over. TRUST ME,, If there's something wrong, that DTC will be back.
We can go from that clean sheet!
Bill
To '99 C5 Error Codes
