What is the best way to fix a worn out headlight motor and lift parts ? Is it better to just replace the plastic gear with a Dorman # 42400 or just go with complete replacement motor assembly ? there is a video from C&S Corvette where Lyle (how is the video host ) I watched in which he didn't recommend using a brass replacement gear but us a replacement plastic gear I mentioned here, In watching the video he makes the case that the reassembly process isn't very successful using any epoxy on the market, and that you need a steel bracket to do this repair correctly ? What say forum members ?
Rodney Dickman sells a kit that has brass gear, epoxy, everything you need.
You can cheap out and get a made-of-chinesium knock-off with plastic gear. But my experience is that those fail muy pronto (i.e., very quickly).
When I pulled my motor apart to do the repair, I could tell the gear mesh wasn't very good and it made sense that it started slipping and eventually stripped the gears. The motor itself had a little play against the plastic housing. It's held on by some tabs and I was able to bend them a little tighter and reduce the slop.
It depends on the style of motor. The 00's to 04's are different from the 97's - 99's.The former has 3 small bolts attaching the top and base and the other uses an epoxy. uses an epoxy. I watched Lyles video and went for the replacement kit. I went with his kit which has that "T" bracket.
Hip Hip Hooray for you.
The gear in my chinesium motor lasted about 24 months.
Do you guarantee that your results will be experienced by others? (Of course you do./s)
