C6Z shock on c5z help!
Old Dec 29, 2023 | 04:35 PM
Akaz06's Avatar
Akaz06
Default C6Z shock on c5z help!
Hi
anyone have idea about c6z shocks on c5z it will fit or not ?
C6z shocks part number:
10313647
25819268
thanks
Old Dec 29, 2023 | 04:48 PM
Smoken1's Avatar
Smoken1
Yes they fit, I have them on my 02 vert along with the C6 Z51 sway bars
Since you have a Z06 you would need the C6 Z06 sway bars
Old Dec 29, 2023 | 05:32 PM
Akaz06's Avatar
Akaz06
So it will not fit without c6 z sway bar ?
Old Dec 29, 2023 | 05:54 PM
Smoken1's Avatar
Smoken1
The shocks will work just fine, I was just adding which sway bars you would need
Old Dec 29, 2023 | 10:58 PM
MetalMan2's Avatar
MetalMan2
I run C6Z shocks on my C5Z, no other changes so still running C5Z leaf springs and sway bars.
Old Dec 30, 2023 | 07:41 AM
Akaz06's Avatar
Akaz06
Great
Old Dec 30, 2023 | 12:15 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
As others have noted, no issues at all with C6Z shocks on an otherwise stock C5. I replaced the F45 suspension in my '99 with C6Z shocks and a C6 Z51 sway bar.
Old Jan 1, 2024 | 08:34 PM
MY03C5Z's Avatar
MY03C5Z
C6z shocks on mine for around five years now, zero issues or regrets.
Old Jan 1, 2024 | 09:14 PM
Mc556's Avatar
Mc556
Hi
10313647
25819268
thanks
They fit and work with stock c5 or aftermarket sways
Old Jan 5, 2024 | 03:48 PM
Akaz06's Avatar
Akaz06
its fine with c6 z06 sway bar ?
Old Jan 6, 2024 | 12:09 AM
Navy Blue 210's Avatar
Navy Blue 210
Rear C6 Z bar is best used with AT LEAST 315 size rear tire.
Below, the C6 Z51 rear bar is a Much better fit.
Old Jan 6, 2024 | 06:58 PM
Mc556's Avatar
Mc556
I don’t see any issue with shocks fitting with any sways. As far as c6z sways fitting a C5 I’d think they would be the same you would also need the c6z bushings.
Old Jan 6, 2024 | 06:59 PM
Mc556's Avatar
Mc556
I’m using the Steinjager with adjustable links on my personal car. I also have Viking coilovers.
That setup is working good with 19in 305s but I wish I still had my c5 z06 rear to swap in just to test.
I get a slight bit of understeer if I push it hard at Autocross. I have 18in 265s up front so going to switch to a wider front
Old Jan 12, 2024 | 12:08 PM
Jason B.'s Avatar
Jason B.
I have a 2000 coupe with the base FE1 suspension. It's lowered on the factory bolts for looks. It's time to replace shocks and I keep seeing that the C6Z shocks are "better for lowered cars". I'm wondering if anyone here can comment on ride difference? My car is a daily commuter and doesn't see any track time. I am completely satisfied with the ride and performance of the FE1 suspension for my use and don't want a stiffer ride. Do just the shocks make a noticeable difference in the stiffness of the ride?
I just don't want to buy factory replacements if it's true that the lowered height will shorten the life.
To C6Z shock on c5z help!
