Malfunctioning headlight
Old Jan 10, 2024 | 08:58 AM
RAM2003's Avatar
RAM2003
7th Gear
Default Malfunctioning headlight
When I turn on the headlights of my 2003 Corvette both headlights open. When I turn the headlights off both lights close but then the left headlight reopens about halfway. How do I get the light back to operating properly? The headlight motor for that light was replaced in 2021.
Old Jan 10, 2024 | 02:26 PM
yellow2007's Avatar
yellow2007
Have you recently done any work on them like change to leds?
Old Jan 11, 2024 | 03:21 AM
RAM2003's Avatar
RAM2003
7th Gear
No, the only thing that I did was replace the headlight motor.
Old Jan 11, 2024 | 03:54 PM
yellow2007's Avatar
yellow2007
Are the small white bushings in place? Could also be the headlight control module. When it's stuck halfway up, try rotating the **** to the close position and see if it re indexes. Has this just started?
Old Jan 12, 2024 | 09:55 PM
RAM2003's Avatar
RAM2003
7th Gear
i have closed the headlight using the **** but it does not reindex. The problem started last summer.
Old Jan 12, 2024 | 09:58 PM
RAM2003's Avatar
RAM2003
7th Gear
I have closed the headlight using the ****, but it does not reindex when I turn the lights back on. The problem started last summer.
Old Jan 13, 2024 | 12:02 AM
ncali's Avatar
ncali
get a set of the white bushings from Rodney Dickman
To Malfunctioning headlight
