c5 HVAC indication when passenger side control moved.
Old Jan 13, 2024 | 03:41 PM
sboblett's Avatar
sboblett
Default c5 HVAC indication when passenger side control moved.
I have a 2001 C5 Corvette Convertible and have a stupid question. On the automatic HVAC system when the passenger temperature control is moved is there an indication on the control panel that it is being adjusted. I know my other cars with a dual control system when the passenger **** is turned the temperature setting for that side is displayed as is the temperature setting for the driver's side. Is there any indication on this system, I really do not remember? I know in Auto the temperature setting for the drivers side shows.
Old Jan 13, 2024 | 07:03 PM
bookyoh's Avatar
bookyoh
Keep in mind this is an automatic temperature control designed in the 90’s. Probably pretty “high tech” back in that decade.
The passenger side **** is a relative adjustment from the setting you see in the display and does not display the passengers temperature setting.
Old Jan 14, 2024 | 08:25 AM
Markmbaha1's Avatar
Markmbaha1
It does not display anything. In fact there is question if it really does anything. Lol
Old Jan 14, 2024 | 09:17 AM
yellow2007's Avatar
yellow2007
I've always question the wisdom and value of a dual climate control in a car where you are literally a foot away from each other....
Old Jan 14, 2024 | 09:27 AM
Markmbaha1's Avatar
Markmbaha1
Kind of like no smoking section on an plane. The row in front smokes and your row in non smoking immediately behind, doesnt get smoke. Lol. Kind of funny.
To c5 HVAC indication when passenger side control moved.
