OXY SEN Fuse keeps blowing....
Old Jan 14, 2024 | 02:06 PM
Rockitansky775's Avatar
Rockitansky775
Default OXY SEN Fuse keeps blowing....
Hi all, I have a 2002 track car that keeps blowing the OXY SEN 15amp fuse whenever I turn the key to start. I have long tube headers and have only the upstream flat 4 O2 sensors. The car will run fine but as I scan using HP tuners scanner, the bank 2 sensor 1, reading are fine at cold start up then go low volts after it heats up. Bank 1 sensor 1 reads good at around .440 volts but pax side goes anywhere from .200 to .900.
Any suggestions as to where I should start with chasing down this probable short? THX!
Old Jan 14, 2024 | 02:07 PM
Rockitansky775
The bank 2 volts vary wildly whenever I give it gas, but then seems to settle back to normal at idle....
Old Jan 15, 2024 | 07:30 PM
Rockitansky775
Disregard, just found out bank 1 sensor 1 was the cause of the 15amp fuse blowing. I guess it really doesnt matter which side as it still blows the same fuse.
To OXY SEN Fuse keeps blowing....
