Corvette C5 not starting
I have a Corvette 1999 C5
Over Christmas- stopped at a shop- went to jump back in and all i heard was click! so tried to jumpstart it - did not work - just click
Had to get it transported home
Ok i have done all things i can think of on google including:
1/ Replaced Starter Motor and Solenoid -
2/ I tested the starter motor in 2 ways
a) direct to the battery to ensure it was good-=result: it worked
b) had it on the floor underneath the car connected to the cables (power,switch,earth) -result : it worked when turn key then bolted into car: result: clicking when turn key
3/ Tested battery: result 12.9 volts- but just in case used good battery from another car
4/ tested power cable underneath which goes to starter: result: over 12Volts
5/ checked all fuses and swapped relays around both fuse boxes by battery and in passenger foot space
6/checked all ground cables and sanded back all ground locations and put back
7/Put new starter motor in and sanded back all cable connections going to the new starter : result: many clicks but no start
8/ thought of the TDR however switch works and security message goes away once turn key plus starts starter motor when on ground connected to main wires
In Summary to date:
Switch -Working: works because could start starter motor when it was on ground underneath connected to the wires
Starter Motor Works: have tested it in many different ways (new)
Ground Locations good: sanded back all connections- i have taken off and cleaned even though no corrosion was evident on any(clean wires etc)
Battery Good: Have changed battery with working one from different car
Battery Leads-good have sanded back and lubricated to ensure perfect connection
Also: checked power going to fuse box- over 12 volts
Checked fault codes : None
This has really stumped me - please let us know what else i should be checking
I really don't want to have to call in a mobile auto electrician
thanks
Last edited by Gary Johnson; Jan 20, 2024 at 03:15 PM. Reason: add extra information
it was a pretty big job taking off top of exhaust and taking out starter- is there another way
Ok just been out there and had my wife turn key and clicking noise seems to come from motor - not starter motor or fuse box?
clicking seems to come from electrics top of motor? maybe i am wrong?
Not sure what this means?
thanks and any advice would be great
Last edited by Gary Johnson; Jan 20, 2024 at 04:13 PM. Reason: add more information
Please let us know if any of these could be the reason for not starting
A1-RDCM
B2283H and B2285H
A6-SCM
B0851H
AO-LDCM
B2282H
B2284H
28-TCS
C1255H
99-HVAC
B0365H
B0367H
B0446HC
ok talking with another mechanic
Because i had the starter going underneath the car and it worked
I was told to take off front belt and get underneath and test with a screwdriver while it was bolted in
to my disappointment it turned over really really slowly and did not start
I was told this is most likely a internal problem
Anybody know what this could be?
I would still test with another known good battery as your battery could have a bad cell and still read 12.9 but still fail when load is placed on it.
Did you remove the wiring harness clean connections at the location under the hood near the battery, BCM cable at passenger foot inspection, Confirm voltage from battery to fuse box is good or take apart fuse box 3 sandwiched pieces and clean and inspect wiring under fuses and pins.
Sometimes a bad connection on the pins can cause that
You cleaned your key / ignition but did you try with a different key?
is it auto or manual ? Is the column locked or do you here the steering wheel unlock when turned to on position?
lmc5 possibly installed?
Read these?
http://forums.corvetteforum.com/showthread.php?t=896875
Check BCM cable and clean contacts?
https://www.corvetteforum.com/forums...problem-4.html
https://www.corvetteforum.com/how-to...e-start-368434
https://www.corvetteforum.com/forums...post1577044954
https://www.corvetteforum.com/forums...limp-mode.html
Security light turn off when key in the on position? https://www.corvetteforum.com/forums...post1577044954
Being that you could get it started with out turning of the key sounds like the issue is between the ignition switch and BCM / TDR
any chance its related to ignition coils, plugs wires since it ran rough when you did get it to turn over?
Maf sensor wire cleaned?
This post talks about turning to on letting it sit for a bit before cranking to troubleshoot TDR relay.
https://www.corvetteforum.com/forums...rning-key.html
