Clutch replacement
would love to do myself and go through the car myself. Half challenge half curious. Half tall task.
I have space in my garage.
Does anyone regret doing this job. How many hours . I assume professionals do it in 11 hrs so I will budget 44 hrs? Mostly on weekends?
I would need to get taller jackstands and tranny jack
im located in CT
just did harmonic balancer , seal . New tie rods . Valve springs and seals . The pilot bearing I believe is shot . Car is 2003 c5z with 70k . All stock and newbie c5 owner
That being said, you have the parts, time, and space. A clutch job is no harder than a harmonic balancer. It's a step by step job, the only difference is that the parts you need to remove and reinstall are much heavier and bulkier.
Jackstands that get your car 20"+ in the air are very helpful. A Motorcycle/tranny jack is super helpful, and a couple other jacks on wheels. And of course a second person helps immensely, especially if/when you decide to drop the rear cradle/tranny and diff/torque tube in one piece.
While you're in there, it'd be silly not to replace the rear main seal and install a remote clutch bleeder.
Cheers!
@Markolc1981 and I are both in CT here too - small world.
For the time and effort investment (or money if you pay someone else) it is one of those things where I have an easy time saying "while I'm in there....."
That mostly includes: remote bleeder, lightweight fly, 12mm TT / rebuild, tunnel insulation, tunnel plate
Hope to see it out there this summer!
Couple suggestions…get a transmission jack/cradle for the rear end. That will keep it stable and under control. Second, some big, stable jacks, two floor jacks, and at least four, maybe six jack stands. Big ones with wide base and go high enough.
I happen to have my car in the air right now, but just for removing the steering rack and exhaust. Four jackstands under the body lifting points, two under the front cradle, rear tires on ramps, floor jack under rear cradle. Im risk averse, lol.
Key point here. When you have the drivetrain ready to drop, have a friend there to help. Maybe one of these guys might help you through the exciting part.
Sounds like a good adventure. 👍
Also, my suggestion would be to support the tt / trans / diff then separate and lower the rear cradle first, then pick the entire remaining assembly with the trans jack. If you look at my entire thread here there's a video near the end where I demonstrated how the entire tt / trans / diff assembly balances perfectly on the trans jack. That's absolutely essential to doing this job solo.
As soon as the weather improves and my shop floor increases in temperature a bit I'll be doing the entire thing again, as it seems I botched the rear cover alignment (rear main seal leaks).
That said, I found a number of professional mechanics had worked on mine previously, and had cut numerous corners in order to get the job done inside that mystical 11 hour window.
Its not a particularly hard job, just lots of stuff to think about while doing it.
I did the clutch and torque tube last year, barely drove it, now my trans needs to come out to fix a leak.
I see you have "67" in your username; if this is either your age or the year you were born, you're probably at a station in life where you get sore just sitting in one position for 40 minutes... or get sore exercising... or get sore going to the gym. Or get sore driving to work. Or reading a book.
So unless you're pretty flexible and markedly stronger than most septuagenarians, you might consider having folks with more kit and younger workers take their shot at it.
I would much rather do a clutch than the harmonic ballancer.
https://www.z06vette.no/2023/10/install-drivetrain.html
https://www.z06vette.no/2023/09/torq...intenance.html
https://www.z06vette.no/2023/08/new-...ine-seals.html
https://www.z06vette.no/2023/08/remo...rivetrain.html
Get some tall heavy duty jack stands, a transmission jack is a big help and a metal clutch alignment tool, do not rely on a plastic one that comes in a cltuch kit.
Mine fought me tooth and nail - headers in the way, rusted brake lines that started leaking after being molested, you name it. Long story short, when you get down to having the flywheel off, you'd be well advised to consider Murphy's law, or as I put it: "might as well do it now b/c I don't want to do this one again".
As for the clutch alignment tool, I had zero issues with the plastic one. The key is to periodically test the fit (slide it out and back in) as you're snugging up the pressure plate bolts. If it binds going back in you know your friction disk has moved and need to back the pressure plate bolts off and start over.
I just put mine back up on the wheel dollies in preparation for correctly repositioning the rear engine cover and main seal. Hoping to start Tuesday morning and be done Thursday afternoon (won't be able to work on it Wednesday). I would be happy to document the process if anyone's interested. Having done it numerous times using different methods, I personally think pulling the entire assembly out with the cradle attached is a phenomenally bad idea, but just my $0.02.
We support the trans with the trans jack and used to use a large jack on the subframe. Drop the sub frame as one unit. We unbolt the the upper a arms.
Then drop the diff, trans, tq tube as another unit on the trans jack.
Using a second trans jack on the subframe was easier to use than a jack.
The SAC City cover alignment / install tools help with engine seals. We also use an Amazon engine stop that bolts in place of the starter when we torque down the flywheel or harmonic balancer.
I knew about this beforehand but thought I would be thrifty and borrow my friend's Dorman tool, which is far less idiot-proof. Lesson learned, I still ended up buying the Sac City tool, but also get the joy of repeating the job in the name of saving $50. Not fun.
1 - The shop manual is your friend.
2 - There are lots of vids on the youtube showing the process.
3 - If you have the tools, time, inclination and patience, there is no reason why not.
4 - As others have mentioned, there are lots of "while you're in there" things to consider, such as the engine rear main seal, pilot bearing, throw out bearing, clutch slave cylinder, clutch remote bleeder, giubo joints and etc. It would also be a great opportunity to add some heat shielding to the tunnel, if your tunnel gets too hot in the Summer.
Make sure that you fully understand how to install/position/shim the slave cylinder.
Make sure that you label which lambda sensor lead is which.
Have fun!
