Lifter link bars noise
Old Jan 23, 2024 | 05:49 PM
jfigus's Avatar
jfigus
Default Lifter link bars noise
I recently installed new lifters and heads on my 99' C5. I went with Comp Cams Evolution lifters with link bars. Upon cold start I'm now getting a chirping noise from the engine. It's not the accessory drive, confirmed by starting with both belts removed. I'm now suspecting the link bars. Is this normal with link bar lifters? Is this a break-in symptom that will eventually go away? The chirping does go away after the engine is warm, but returns on the next cold start. Thx for the help.
Old Jan 24, 2024 | 02:52 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
My guess would be the preload maybe a little low and cause the chirp. Did you measure for pushrods lenght with the new lifters?
Old Jan 24, 2024 | 03:18 PM
schmuckingham's Avatar
schmuckingham
I have short travel link bars in my car and they are noisy but it is a ticking sound, not a chirping, and is worse when warm vs. cold. Might want to pull them and check to be sure everything still rolls free.
It could be too much preload until the car gets warmed up. Car run OK cold?
To Lifter link bars noise
