Help Finding a Short - Dash Reset and RFA
1. It sat outside while I was traveling for work for 3 months, and lots of moisture in the car. The carpet on the passenger side was pretty wet.
2. I've installed long tube headers and I cooked the wires on the passenger side that go to the ground, starter, O2, CPS. I have repaired these once with solder and heat wrap. I still had the issue, so I cut that out and repaired with crimps and heat shrink.
The car has intake, headers, and a tune as far as engine mods go. I do have HP tuners, but I really only use it for data logs and diagnostics.
Below are of some of the observations that I have noticed when it is acting up.
- Key fob does not work (RFA - no comm.)
- Voltage drops to 10.2V when surges
- Dash gauges all cycle to zero as if it is going through startup
- Memory in dash screen is reset
- Bucking
- P0135 H C
- P0155 C
- U1176 H
- U1064 H
- B2265 H
- U1000 H
- U1255 H
- U1096 H
https://www.corvettesalvage.com/c5-c...-descriptions/
The symptoms you experience could be caused by a number of malfunctioning parts including the ignition switch which is a common problem. Need accurate codes-
I haven't had any ignition/starting issues at all throughout this adventure. My initial thought is something is shorting out somewhere but I have no idea where to look first.
I looked at the ground at first and it appeared to be clean, but I took it off and it was covered in oxidation on the bottom of it. Feeling pretty dumb now since that is literally every electrical post on this site.
Thanks for all the advice fellas. I know a lot more about my electrical/ignition system after this weekend.
So technically it could have been one of those. But the one behind the passenger seat was the only one that looked oxidized.
