Help lowering radiator....
Old Jan 26, 2003 | 03:58 PM
Phil97SVT's Avatar
Phil97SVT
Default Help lowering radiator....
I need to lower my radiator about 2-2.5" or make it flush with the top of the frame rail. What is the easiest way to do it and does anyone have any tips?
Phillip
Old Jan 27, 2003 | 10:45 AM
davidfarmer's Avatar
davidfarmer
Default Re: Help lowering radiator.... (Phil97SVT)
You will have to build/modify the lower mount. You know, the one that already scrapes the ground all of the time. The radiator sits on top of it, so you could modify the radiator support to allow it to sit lower, or you might be able to move the mounts slightly forward, then lay the radiator down at more of an angle, lowering the top relative to the frame. Either way, you are going to have to fabricate a new shroud, and possible cooling lines, as well.
Dave
Old Jan 27, 2003 | 02:57 PM
scool93535's Avatar
scool93535
You might touch base with Andy at A&A. He's done it for SC mods and such.
:cheers:
To Help lowering radiator....
