Clutch assembly balance?
We now see that the GM online info refutes this with the "Four Senarios" discussed earlier in this thread. And we know that many members have done the weight swap by the book and ended up with a shaker, while other have hung a zero balanced wheel/PP assembly on their cars and were dead smooth. And maybe there's some guys who have swapped the weights like they're "supposed" to do, and the result was fine.
So, are we any closer to understanding the truth?
I have an associate at GM Powertrain (he used to be on the C5 program) who is going to try to find the "right person".....someone who knows for a fact how the LS1/6 engines are balanced, and what's the deal on replacement wheel/PP assemblies, etc etc. If I can somehow get very lucky and "get connected", you can be sure I'll post the results.
Chevy says that the LSx engine is internally balanced which means that they are balanced without an external balance weight as used on the old SBC 400 or the BBC 454’s. They also say that the flywheel /clutch and the damper are zero balanced but they seem to miss this on occasion.
Every Vette engine is final balanced after assembly by running it on a test stand that measures the total engine/damper/flywheel/clutch imbalance and shows the tech where to put standardized weights on the damper and/or flywheel. If they assemble an engine with a badly balanced flywheel /clutch assembly this may fix it. This procedure does not tell them if the flywheel/clutch was zero balanced! It can only balance the total system. This is a very sophisticated system that Chevy is very proud of and it does make our cars better.
The only way to change a flywheel/clutch and assure that your engine balance does not change from this factory value is:
1.) Mark the old flywheel and crank before you take it off so that you know where it was in relation to the crank. This is necessary because it was balanced with just this one crank, rods, pistons, etc. The stock pressure plate can only go on one way due to the position of the dowels so you don’t need to mark it.
2.) Take the old & new assemblies to the balancer and have them match the balance of the new to that of the old. This may not be zero balance but it is the best balance for the parts that were in the engine when it came from the factory.
If you use a zero balanced clutch assembly and you also take the weights out of the damper, you will have an engine that is balanced as good as a Camaro! Maybe that’s good enough. If you change the crank, rods, pistons, etc you can balance the crank for the new parts and then go to a zero balance flywheel /clutch and damper just like a SBC.
Good luck,
Steve
:seeya
[Modified by SNW Vette, 12:44 AM 2/2/2003]
Hopefully, I can confirm this if I hear from a GM Powertrain guy.
Robert
QUOTE]SNW--If you are correct (and it sounds correct to me), this would explain all the odd results that we have seen on this forum from all the various combinations of replacement wheel/clutch assembiles. But it also means that a guy has NO RELIABLE WAY to install a correctly balanced assembly. It's simply a crapshoot, except to go to the trouble to balance-match the new flywheel to the old.......including matching an imbalanced factory condition. This seems like insanity to me, to design a mechanism that a dealer can't reliably replace.
Hopefully, I can confirm this if I hear from a GM Powertrain guy.[/QUOTE]
You buy a replacement FW/PP zero balance and install. Now what happens if you replace the front pulley??
It really seems like GM is doing everything possible to make it impossible for the DIY'er to do anything and have it come out right.
As a matter of fact, I'd bet the dealers don't want to get involved with a clutch swap if it's really this difficult. They would like to get it right the first time so they don't have you coming back again and again during the warrenty period on the work to get it right. They'd loose money on the service.
Could the problem be changing the stock Ls1 clutch assembly for a Z06 assembly be the problem????
:cheers:
Do you agree?
That would make sense to me, however, a dealer would have to balance the clutch assembly prior to installing a new clutch. That just doesn't sound like something a dealer would do.
Another issue might be my change from a stock to Z06 clutch. I did notice two of the three mounting arms have, what looks like rivets in them, that are missing on the 3rd arm. Perhaps there is something different, in the internals, between my early (97) LS1 and the LS6? I could buy that also. I seem to recall reading some where that the LS6 uses a different piston.
If that is true, then the only way to get a Z06 clutch smooth on the LS1, would be to zero balance, test and move the weight if needed to fine tune it to the LS1.
Thanks for all the feedback.
Steve
:cheers:
The LS1/LS6 has an internally balanced crankshaft. This is clearly stated on the National Corvette Museum website under 2002 Z06 info - "Power Boost" http://www.corvettemuseum.com/specs/2002/power.shtml
However, the repair manual refers to the balancer on the front of the engine as a "Crankshaft Balancer". The manual also states that the pressure plate is mounted on the flywheel so the light spot on the pressure plate is matched to the heavy spot on the flywheel.
I have copied the pertinent pages from the 2000 repair manual regarding clutch removal and installation, and a section on vibration analysis to a web page at http://temp.corvetteforum.net/c5/steve_row/index7.shtml .
I do not have a copy of the document entitled "Engine Balancing" which states that the weights should NOT be transfered to the new flywheel when replacing the clutch assembly. However, I have seen and read it. And my Z06 is proof that it worked. This document applies to all C5's from 1997 to 2003.
Another curious thing is that the F-body version of the LS1 has no weights in the balancer or the flywheel and furthermore the front of the crankshaft is keyed for the balancer. For some reason the F-Body information is included in the 2002 Corvette repair manual ( and perhaps other years) which I spent some time reviewing this evening to be sure that nothing had changed from the 2000 manual. And nothing concerning the balnacing weights, etc., had changed. There have been some improvements in software and procedure for the Engine Vibration Analyzer.
It would appear that the only way to insure that you remain vibration free when changing the clutch assembly is to take the original assembly and the new assembly to a machine shop and have them balance matched so that the weights will work in the new assembly as they did in the original assembly.
I would certianly like to hear from one of our Corvette repair technicians on this subject.
I heard from my pal in GM powertrain today......but he's still trying to get with the right guys, both of whom are on travel. He's still on the case, and has promised to get back to me next week with some credible info. [Note: my guy is not the balance guru, but he knows who they are!!]
Robert
Nothing yet. I'm at the long end of a "favor" line. But, I'm supposed to harass my contact sometime this week, so thanks for the reminder.
I would LOVE to get to the bottom of this. Keep your collective fingers crossed for me. I hope to have the Straight Dope from GM Powertrain, but don't hold it against me if I fail.....it's not for a lack of wanting!
