Oil Cooler Line Replacement - Transmission
Old Feb 15, 2024 | 08:57 AM
Esq's Avatar
Esq
Cruising
Default Oil Cooler Line Replacement - Transmission
Have a leak on the transmission coolant line that runs from the radiator to the transmission (see image below). Would like to place both the lower and upper transmission oil cooler lines (GM Part Numbers 10425292 & 10229483).
Anyone have any experience or insight they can share? Per the service manual the removal of the lines is 39 steps (page 7-226) and installation of the lines is 40 steps (7-231) (I've attached the scanned pages to this post).
Location on the transmission coolant lines where pipe is leaking
