Rear diff swap
Old Feb 15, 2024 | 10:58 AM
Grute's Avatar
Grute
Default Rear diff swap
Hello everyone, I'm swapping out my 2.73 rear in my '99 C5 auto, for a 3.15. Does anyone know if the transmission needs to be reprogrammed after the swap? If so, what program, or device should I use? Thanks Very much for your help!
Old Feb 15, 2024 | 01:43 PM
JCMDoug's Avatar
JCMDoug
I had a local tuning shop reprogram mine, I did the same swap to 3.15s they need to program a MINUS 15% change in the shift tables, I was told they did not touch the part throttle 1-2 and adjusted part throttle for 2-3 shifts and 3-4 and all the wide open throttle. They found all the information on the HP tuners forum, they sue HP-Tuners for all their programing.
Old Feb 16, 2024 | 12:41 PM
Mc556's Avatar
Mc556
Yes you will to get your shift points corrected.
If you don’t have the 3:15 already go for a 3:42 takeout. You will notice the performance much more. Just my opinion
Old Feb 16, 2024 | 01:20 PM
Missileboy's Avatar
Missileboy
yup, swapped my 2.73 for a 3.42SP last Aug, had ECS do the TCM tune while they were doing my SC upgrade. The car will drive after you swap, but the shift points will be off and you might throw a speed related or transmission slipping code (until you get it re-programmed) as the rear end diff speed will be out sync with the old programmed rear ratio in the TCM.
And don't be fooled by buying a handheld Tuner to do the re-programming, you need/want this done right and you need a real tool like HPTuners or other like tools to re-program the trans correctly. Better to pay someone once and get it right the first time.
Old Feb 16, 2024 | 01:45 PM
YellowZ06-427's Avatar
YellowZ06-427
3.42's are the way to go.
Old Feb 17, 2024 | 08:11 AM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
^^ I second that. If you're going to go through the trouble of changing the diff go with 3.42. I currently have 3.15 in my 2K Coupe, it will have 3.42 soon.
Old Feb 19, 2024 | 04:06 PM
Grute's Avatar
Grute
Thanks for the input!
Old Feb 19, 2024 | 04:14 PM
Grute's Avatar
Grute
Were you happy with the results of changing the rear?
Old Feb 20, 2024 | 10:26 AM
grinder11's Avatar
grinder11
I had the 3.15 gear as OEM (G92 option). The 3.15 will help you, but not as much as the 3.42. But as posted, if you don't already have it, go 3.42. Some guys even go with a 3.73, which was never available from GM. One thing to keep in mind that you seldom see. That would be that the lower ratio (higher numerically) diff you go with makes it easier for the 4L60E trans to turn the axles. A small point, maybe. But the 4L60E isnt known for maximum durability, so any help you can offer it can't hurt any.....
Old Feb 26, 2024 | 03:09 AM
vette4fl's Avatar
vette4fl
To Rear diff swap
