C5 Alternator
I am needing to change out (not replace) my alternator when I go to one of the vendors' bracketry system for the alternator, power steering and a/c units. I have a couple of concerns regarding the alternator and the a/c unit. The alternator on my '99 is a Valeo unit with the VR attached to the back of the case. Of particular concern is (based on what I have read) that the alternator converses with the BCM and if they don't shake hands properly, a fault code would/could get thrown thus being a problem for inspection time. I also read that a tuner could get it programmed to accept the non-OEM alternator by flashing process. My question, if I need to change my alternator in order to use their bracketry what alternator would you recommend, and can I bump the amps up to a 140ish without causing issues? Several of the vendors for the brackets I am thinking of (LSX, CVF, DD, ICT) have advised me to purchase this Powermaster 160 Powermaster Alternator Wiring Harness Adapters | Summit Racing in order to make the alternator work properly with the BCM.
The power steering location on the unit bracketry causes no issues that I am aware of.
The A/C may need to be located to either the high or mid position on the passenger side depending on which vendor I go with. Some of the vendors recommend a Sanden unit and some say I can use my OEM unit so there is that. If I go the high mount route, I know I am restricted to the hood height since I don't want to damage the hood or anything else for that matter. Question is have any of you used any of these vendors for changing out your brackets and has anyone relocated the A/C unit from the low position to either the mid or high position? Thanks in advance and cheers!!!
EDIT: Increasing the output of the alternator should not be a problem. The only issue that I can potentially foresee is with a much heavier electrical load on the car, the engine may have a little trouble idling, especially when cold. I doubt that you will run into this, though at only 140A.
On older cars the L wire went directly to the Generator light on the dash and effectively acted to enable / turn-on the alternator so that it would charge. On our C5s, the PCM controls alternator directly. The field circuit controls the amount of output from the alternator, so that the PCM can proactively control the idle speed of the engine, rather than passively react to the idle speed requirements. IIRC, this is a PWM signal, rather than a serial communications link of any kind.
Yes, the PCM monitors for both low system voltage and high system voltage, but no serial communication is necessary for the PCM to make those determinations / diagnostic decisions. If the PCM is unhappy with the response from the alternator as the field circuit is adjusted, the PCM asks the instrument cluster to illuminate the MIL via a serial comms message over the CAN bus.
I confess that I am more familiar with older GM alternator circuits, so I'm sure that someone will jump in to confirm, deny, or supplement my ramblings. lol
Thanks...Al
Thanks...Al
