Question about axles
Reading up 09+ ZR1's has stronger 33 spline axles, and my axles need to be replaced while I am here. I am going with the SKF hubs with ARP studs ect,
I know the hub ends of the axles are different (31 vs 33 spline) are the diff ends of the axles all the same 97-13?
Basically if I get the 33 spline rear hubs, will the 33 spline hub side axles fit in my differential? Splined the same ect?
Thanks.
