Advice Needed - Drivers Side Window
Old Mar 7, 2024 | 12:47 PM
JanMan99's Avatar
JanMan99
Default Advice Needed - Drivers Side Window
So, I had to realign the drivers side window that was not fitting properly. Got that done. Put everything back to specs & now the drivers side window will not
operate at all. Passenger side.window & door locks all work normally but drivers side will not operate at all. Have checked the power source to the window/door controller & everything fits good. I am no electrical whiz by any means. Any advice is appreciated. Oh forgot...2001 Z06
Old Mar 7, 2024 | 01:07 PM
mmartinez's Avatar
mmartinez
When you say that you have checked power to the window and door controller and everything fits good does that mean you have taken a multimeter and measured voltage? Check the connectors in the rubber accordion sleeve between the door and car, there are male/female contacts that become loose over time.
Old Mar 7, 2024 | 02:01 PM
JanMan99's Avatar
JanMan99
Will do....thanks
Old Mar 9, 2024 | 08:22 AM
CMC76's Avatar
CMC76
As stupid as this sounds. I messed with window power for weeks. Put in a new switch panel. Still nothing. Out of frustration, I popped the switch out spun it around 360 degrees with the wires attached and it's worked now for 3 years. Leads me to believe tension on the wires keeps the pins seated better or something.
Old Mar 9, 2024 | 09:15 AM
JanMan99's Avatar
JanMan99
I will try that....still haven't figured it out yet....thanks. Got a new controller ordered.
Old Mar 12, 2024 | 09:11 PM
JanMan99's Avatar
JanMan99
Got my new OEM window/door controller today.....installed it and everything works as it should. Thanks to all who commented.
To Advice Needed - Drivers Side Window
