Vibration / Clutch washer Question
When y'all talk about adding a washer and testing for vibration, I assume you're reattaching the headers and doing all the testing, then detaching them in order to access the outside bolts on the bell housing panel, correct?
It may seem like a silly question – I was thinking, "Holy crap, that would be a loud test with unbolted headers."
There's a good thread on hot balancing, which I was able to contribute to as well: https://www.corvetteforum.com/forums...post1604539030
My Z06 has stock exhaust manifolds and midpipe, so all I had to do was disconnect the midpipe from the manifolds and cat-back exhaust to remove the clutch inspection cover. Then reinstall midpipe and keep it that way for the whole hot balance procedure.(of course, remove again to reinstall clutch inspection cover)
I'm not sure how headers would affect your access but that would certainly add complexity to this process.
And yes, you'll want to reattach the exhaust system.
