knock sensor
Old Mar 17, 2024 | 10:24 AM
link9a's Avatar
link9a
Default knock sensor
Hi .. what the good knock sensor and harness to go with ? l know NAPA are good but they are pricey and AC Delco are defected for now. Any other options ? How about dorman with harness any info ?
Old Mar 17, 2024 | 10:30 AM
grassblaster's Avatar
grassblaster
I just had napa ones put in my 6.0 truck 3 weeks ago. So far so good.
Old Mar 17, 2024 | 11:51 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Anything electrical made by Dorman are JUNK !!!!
Old Mar 17, 2024 | 12:18 PM
captain vette's Avatar
captain vette
What’s wrong with AC Delco?
Old Mar 17, 2024 | 04:34 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
I can say this. I just replaced both my K/sensors and harness with the recommended high dollar NAPA units, that was a week ago. Before I changed them I was getting a P0332 low circuit bank two. Now every time I drive it, sometimes more than once during a single drive I get a P0327, low circuit bank one. Needless to say I'm not real effing happy about this especially as noted the NAPA ones are VERY pricey (over $70 bucks each).
Old Mar 17, 2024 | 06:22 PM
link9a's Avatar
link9a
That weird !!! As I know NAPA are the best I think you have different problem then knock sensor
Old Mar 17, 2024 | 07:36 PM
cdee63's Avatar
cdee63
I do have an update. Went out just to have the CEL come again. Read the code in the parking lot, both banks low circuit input. Tells me it is the harness or the connection. Seeing I just put this all together last week I'll start checking connections tomorrow. To the OP, didn't mean to hijack your post.
Old Mar 18, 2024 | 10:32 AM
MetalMan2's Avatar
MetalMan2
In the last 2-3 years there have been countless reports of people getting knock sensor fault codes after installing AC Delco knock sensors.
On my car I put in AC Delco units "while I was in there" screwing with valley cover stuff and subsequently was treated to a CEL for knock sensors. My old ones were fine (but I had trashed them). NAPA knock sensors fixed the issue completely for me.
Old Mar 18, 2024 | 12:30 PM
cdee63's Avatar
cdee63
Egg on my face. Pulled the intake this morning and what do I find.... I managed to get the harness pinched between the bottom rail of the manifold and the lip of the valley cover. Smooshed the **** out of the wires with actual wire exposed through the insulation. Pretty sure that is my problem , yes I can be a dumbass at times. Vato Zone had another on the shelf, let's see if I can put this one without effing it up too..
Old Mar 18, 2024 | 09:46 PM
link9a's Avatar
link9a
So still the NAPA are the best ...
Old Mar 19, 2024 | 07:29 AM
cdee63's Avatar
cdee63
^^ I cannot say for sure, however I can say if the harness is damaged by a nitwit putting it back together even the best ones will not get the signal to the PCM. I did drive it for around 30 miles after the new harness without incidence. Based on the experience of others I would agree the NAPA ones are preferred.
To knock sensor
