T56 transmissions
Old Mar 28, 2024 | 09:38 AM
seefivezeeohsix's Avatar
seefivezeeohsix
Default T56 transmissions
Hello everyone I own a c5 z06 (2002) and when I call around to see who can rebuild my transmission, everyone is telling me they only replace it with a new one, because the parts needed to do a rebuild are no longer made.
well, if that really is the case, what all should I be looking to have them replace to save myself a trip? I know a little but not a lot.
can someone list me everything needed?
obviously the T56 transmission, but should I also purchase a new clutch, or torque tube, do I need a torque converter? Or is that just for autos? Thank you. Also, does no one really rebuild these anymore? I am in northern California
Old Mar 28, 2024 | 10:03 AM
Eshoremd's Avatar
Eshoremd
2023 C5 of the Year Finalist - Modified
You can have someone pull and replace the trans with a beefier trans from RPM. You probably want to replace the slave, master and install a remote bleeder. I would find a corvette specialty shop in your area if you have one.
https://rpmtransmissions.com/product...ns/tremec-t56/
Old Mar 28, 2024 | 10:09 AM
seefivezeeohsix
thank you. Yes I did try to call my corvette shop just one city over but they told me they no longer perform any kind of work on C5 transmissions… replacement or rebuild.
they referred me to a Chevy dealer in Rio vista to have the work done, and the Chevy dealer recommended a T56 from RPM transmissions. I just don’t wanna throw in a new transmission with no other supporting parts.
Old Mar 28, 2024 | 04:10 PM
FourG63 97GST's Avatar
FourG63 97GST
for starters, why are you doing this? what is your trans doing/not doing?
most quality rebuilders will disassemble, see what failed, and address it accordingly. Yes parts are hard to find, but they're talking about the major parts, like a gears/shafts etc, the parts what typically fails like synchros, pads, forks are availability. https://www.thegearbox.org/T56_corvette.html carries most of these parts.
as for maintenance things to do while you're there, is the torque tube bearings and couplers, clutch, new oem slave cylinder and add a remote clutch bleeder.
Old Mar 28, 2024 | 04:18 PM
seefivezeeohsix
In short, I’ve lost the ability to upshift and downshift into 3rd gear if I need more than 3.5k rpm’s. The car will stay in 3rd if I go in before 3K rpm’s, but if I try to put it in 3rd with more than 3.5K RPMS, the stick will jump back out into neutral. Also 4th gear grinds no matter the circumstances. It’ll stay in gear tho.
I called my local Chevrolet corvette shop, as well as a Chevy dealer nearby, and both told me rebuilds were no longer possible. Partly why I’m here because I am wondering if they are bullshitting me? Also I wouldn’t expect myself to be capable of working on my own manual transmission rebuild. I’ve only ever changed basic parts.
Old Mar 28, 2024 | 04:35 PM
Vox Machina's Avatar
Vox Machina
There are definitely places to obtain t56 parts. Thegearbox.org and AMP distributing are two places I've bought parts from in the last few years. From the looks of it they're still around.
Old Mar 28, 2024 | 04:39 PM
seefivezeeohsix
Well this greatly helps since it would seem I just need the 3-4 synchronizer kit, but now I’m wondering how hard a job this is? I’m guessing pretty difficult?
Old Mar 28, 2024 | 04:52 PM
Vox Machina
That really depends on your technical ability. I was able to rebuild the t56 in my camaro on my own, and that was the first transmission I'd ever rebuilt. If you are careful and methodical it is a doable job. My advice is do a TON of research. I watched probably watched a dozen videos on assembly, disassembly, and bearing clearances.
If you're mechanically minded, go for it. If not, might be best to hand it off to someone else
Old Mar 28, 2024 | 05:27 PM
spfautsch's Avatar
spfautsch
Just to jump in w/ some addl info - if you still have the original M12 transmission, hard parts like gears may not be too easy to find. And unfortunately it sounds like you might need a new 3rd.
May be worthwhile investigating if you still have the factory M12 or if it's been replaced with a more commonly available MN6.
These transmissions aren't difficult to rebuild relatively speaking. Getting the trans / diff / torque tube out of the car is far more logistically challenging. But you will need some specialized equipment to rebuild the trans properly. It's not impossible, but also not something you want to cut corners on. There are plenty of users that would be willing to give pointers, myself included.
The gears for the M12 are the main parts that are no longer available for these. All the other parts are identical to the MN6 (synchro frictions, blockers, sliders, keys, shift fork pads, output shaft, etc.). Everything you would need for a MN6 is available at thegearbox.org and / or txdrivetrain.com. If the output shaft needs to be welded back to correct O.D., TDP is supposedly the place to go for this as well.
Old Mar 28, 2024 | 05:52 PM
FourG63 97GST
That's because they don't want to do it, or have a tech capable. it's something they'll have to outsource, so the juice isn't worth the squeeze for them to lose a lift. this is more performance/aftermarket shop oriented at this point.
Old Mar 28, 2024 | 06:48 PM
seefivezeeohsix
so basically what you’re saying is, I need to either learn how to do it myself, or ask around/find someone in the area willing to do it… damn, lol.
Old Mar 28, 2024 | 07:54 PM
hungryhippo's Avatar
hungryhippo
Check out texas drivetrain performance. Freight shipping is not too bad. I've dealt with them a bit and I'm always impressed.
I was going to rebuild a used one i bought but it needed too many parts replaced. Instead i bought a rebuilt unit from them and sent my used one for a core refund. Its also a good time to build your diff too since its the same shipping cost.
I also plan to rebuild the t56 that came out of my low mileage car eventually. It doesn't seem too bad to do, but its common to need more parts replaced than you think.
Old Mar 28, 2024 | 08:52 PM
seefivezeeohsix
thank you, but this is all assuming I still have 3rd gear, right? Just replacing the synchros won’t help, and since I’m not inclined to do it myself, I’ll have to have a shop take it apart to find out what’s wrong anyway. Quite the pickle I put myself in.
Old Mar 28, 2024 | 09:41 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
We service manual transmission from 1997-2019. We offer exchange or rebuild your unit. Let us know if we can help.
__________________
Old Mar 29, 2024 | 10:46 AM
redzg's Avatar
redzg
There is a series of videos on the youtube of a complete rebuild, including removal, reinstallation, and test drive. 14 rebuild videos and 1 new parts video. Most in the 20 to 30 minute range, 4 hours in total -- but he doesn't skip much.
Old Dec 9, 2025 | 12:16 AM
Preston.Corvette's Avatar
Preston.Corvette
Sorry to be reviving an old thread, but I've been searching everywhere looking for recent mentions of AMP distributing. Id never heard of them until I started my t56 rebuild. Its great to see someone from a familiar forum post this. Are they any good? Their prices on some of these things seem almost too good to be true.
Old Dec 9, 2025 | 12:26 PM
helga203's Avatar
helga203
Because it is. Buddy order gears from them and they were out of spec when he measured them. Thank god for Ebay to step in and get his refund., He had to fight tooth and nails beq ause they said "as is" Why would you sneak that in there. And ebay took them off there site. They probably changed their name to another company to find a lope hole. Stick with the the reputable companies.
You dont want to do this twice.
Old Dec 9, 2025 | 12:49 PM
Preston.Corvette
I Agree, thanks for the warning. Ill probably stay away from them. If I'm not mistaken, they did change their name on eBay to Transpartsonline.
To T56 transmissions
